1. DanielLoreti's Avatar
    There's an app I just can't get notifications from. Worked fine on my S8 and still does, but notifications have not come through even once on my Note 9 since I've gotten it. I tried uninstalling and reinstalling and still nothing.
    09-27-2018 03:47 PM
  2. SpookDroid's Avatar
    Would help to know which app you're referring to. Sometimes you have to disable notifications on the other device to activate them in another. This is a common issue, for instance, with the Instagram app.
    09-27-2018 04:04 PM
  3. DanielLoreti's Avatar
    I'm actually getting Instagram notifications just fine from both my S8 and Note 9. I'm even getting them to my G5 which I still have as well. The only app I'm not getting notifications to my Note 9 is Winter Is Coming. It's a Game of Thrones news app.
    09-27-2018 04:20 PM
  4. SpookDroid's Avatar
    Try disabling/re-enabling notifications in the app's Settings. Also, check that, in the System Settings, the app's notifications aren't being blocked/silenced.
    If it's just that app, it might be a bug related to the app itself with the Note 9, and only the dev could fix something like that.
    09-27-2018 04:39 PM
  5. DanielLoreti's Avatar
    I tried disabling and re-enabling. I'll check system settings now.
    09-27-2018 04:48 PM
  1. Why are my non-gmail notifications delayed?
    Last Post: 09-27-2018, 04:43 PM
  2. Possible to change the font in the notification/status bar?
    By datum9 in forum Samsung Galaxy S8 & S8+
    Last Post: 09-27-2018, 12:40 PM
  3. Constant Unknown Notifications
    By BigIan279 in forum Android 8.0 Oreo
    Last Post: 09-27-2018, 10:57 AM
  4. Problem with my cel. GT-I9195.
    Last Post: 09-27-2018, 10:33 AM
  5. Replies: 1
    Last Post: 09-26-2018, 08:29 PM
