10-14-2018 03:50 PM
64 123
tools
  1. race4life's Avatar
    Is 6 hours SOT good?
    Yes, that's really good.
    10-11-2018 01:53 PM
  2. j_hansen's Avatar
    Yeah AND no... Really..
    Depends on screen brightness/location/bluetooth/signal strength .. etc.
    You could probably push 10 hour SoT tweaking usage and settings
    10-11-2018 02:32 PM
  3. DanielLoreti's Avatar
    Location high accuracy, 40% brightness, no BT, mix of wifi/LTE. 6 hours SOT with 40% battery left.
    10-11-2018 02:36 PM
  4. race4life's Avatar
    Yes, that is very good.
    DanielLoreti likes this.
    10-11-2018 07:14 PM
  5. mlbyanks11's Avatar
    I actually got a brand replacement note 9. I literally didn't charge my phone until 10pm last night. Took it off the charger around 2am last night and standby drain sucks. Don't get why it drained 10 percent while idle.Today battery is draining quicker..-screenshot_20181014-090727_settings.jpeg
    10-14-2018 08:09 AM
  6. Nakrohtap's Avatar
    I actually got a brand replacement note 9. I literally didn't charge my phone until 10pm last night. Took it off the charger around 2am last night and standby drain sucks. Don't get why it drained 10 percent while idle.Click image for larger version.
    If you want great standby time, you should probably consider turning off AOD. While it doesn't consumers huge amounts of battery in comparisons to someone actively 7 using their phone, it still uses a lot compared to a phone just sitting idle. You can click on AOD and it will show you how many mAh of battery it's used.
    thecomicbookandme likes this.
    10-14-2018 09:07 AM
  7. mlbyanks11's Avatar
    You're right it was using 168mah. I disabled it for now and I'll see if it gets better. Appreciate the tip.
    10-14-2018 09:17 AM
  8. mhunter6378's Avatar
    In my experience, AOD uses about 1% per hour give or take a little. I have turned it off in the past but find it useful so I just leave it on now. For those times where I'm not actively using my phone or won't be for a while I just place the phone face down. When the proximity sensor is covered, such as when face down, AOD is turned off.
    10-14-2018 09:53 AM
  9. DARK Vader777's Avatar
    Time for a battery replacement?
    10-14-2018 11:44 AM
  10. mustang7757's Avatar
    I set my AOD on a schedule from 8:30 am until 9pm
    10-14-2018 11:59 AM
  11. Nakrohtap's Avatar
    Mine is almost the opposite. I set mine so when it's on my nightstand at night, I can see the time.
    I just changed it 2 days ago because I noticed that at one point, the AOD was like #2 in battery usage.
    It's weird because when I know there are notifications, I open the screen and check the notification shade. I don't generally pick up my phone and look at the AOD notification icons.
    mustang7757 likes this.
    10-14-2018 12:44 PM
  12. recDNA's Avatar
    Are you not concerned of not being able to track it if lost or stolen ?
    Google has one too
    10-14-2018 12:50 PM
  13. mustang7757's Avatar
    I use the led notification light do it's work once Aod is off
    10-14-2018 12:52 PM
  14. Nakrohtap's Avatar
    Yep. That too. I'm gonna see how it goes for a few days and see what difference it makes on the battery life.
    10-14-2018 03:50 PM
64 123
  1. 2 lightning bolts on battery icon
    By mdlc91 in forum Huawei P20 & P20 Pro
    Last Post: 02-14-2019, 06:52 PM
  2. Replies: 1
    Last Post: 10-07-2018, 03:13 PM
  3. Is Android rooting safety
    By Tylor Turpin in forum General Help and How To
    Last Post: 10-04-2018, 12:10 PM
  4. J7 bluetooth no sound when google is active
    By Edwin_Zank in forum Samsung Galaxy J Series
    Last Post: 10-03-2018, 11:34 AM
  5. Why is my phone all the way down and still making a static noise very irritating
    Last Post: 10-03-2018, 09:18 AM
