Another day
OMGosh! That's crazy!
I live in the country. Rarely us wifi. Cell signal isn't the best. Usually 2 bars. Do you see anything in my screenshot that stands out as a problem?
No I dont see any issues
How low you let the battery go down before charging?
That's almost 6 hours of screen on with max brightness and always on display on if you go all the way down.
You've been on battery for 11 hours which covers most work shifts with juice left for the trip home.
This looks normal.
No, it's just 4 hours of SOT. I guess you're counting AOD. That's supposed to use so little battery that it's hardly worth talking about. If I had it off, I think I'd use more battery by checking the time and to see if I had any notifications. Isn't that the purpose of AOD?
I think he meant 6 hours total screen time if you kept using the phone before it dies.No, it's just 4 hours of SOT. I guess you're counting AOD. That's supposed to use so little battery that it's hardly worth talking about. If I had it off, I think I'd use more battery by checking the time and to see if I had any notifications. Isn't that the purpose of AOD?
I see folks getting 1-2 days out of there battery. I'm lucky if I get a day out of mine. I do light gaming but not a ton. My screen on time varies from 40 minutes to 2 hours give or take. I commute into the city every day M-F and i stream music do some youtube, radio.com sports radio streaming and some texting on that commute. I get to work im down to 81% and by the time i leave my office at 4pm its down to like 60%. Its on standby and the draining stinks. I've wiped cache partition three times. Close out my apps have apps asleep under device maintenance. I run it daily and cannot seem to figure out why I am getting such awful battery life. I am still trying to figure out how you folks get such great battery life. Hard reset is the last resort because its time consuming and the device is a month old and dont see a point in trying it yet. I've been trying to use accubattery but haven't found it very useful just yet. GSAM battery is pretty useless since 8.0 update.
Also - i'm on AT&T 128gb galaxy note 9 and no my service is not low and no i do not have wifi and bluetooth or any toggles that shouldn't be on when not in use. I don't believe I have a defective device.
Any help or additional suggestions is appreciated.
My question is...why is the camera usage so high? I've never seen it listed second in battery usage. That may have something to do with the overall battery stats on that particular cycle.
