1. DanielLoreti's Avatar
    Just noticed my battery stats reset when I restarted my phone. Is this supposed to happen? It says the stats are from last full recharge but that's not the case. I was at 94% around 30 minutes SOT and when I checked again it's now at 92% 8 minutes SOT.
    10-12-2018 10:39 AM
  2. al3azim's Avatar
    This does happen sometimes and other times, it just continues. Not sure what triggers it to change but I have had happen to me
    DanielLoreti likes this.
    10-12-2018 12:17 PM
  3. DanielLoreti's Avatar
    So everything will be ok with battery stats after my next full charge?
    10-12-2018 12:52 PM
  4. al3azim's Avatar
    yes it should be fine.
    DanielLoreti and kptsalami like this.
    10-12-2018 12:57 PM
  5. DanielLoreti's Avatar
    Ok thanks. Just making sure it wasn't going to throw off the battery.
    10-12-2018 02:11 PM
  6. dannejanne's Avatar
    This happens when you restart your phone and you have 90% or more battery left. If you restart when the battery drops below 90% your stats will stay. It works like this on all Android phones.
    10-13-2018 12:55 AM
  1. How to hard reset my susan m5 td-lte 4g lte phone with pattern lock code.
    Last Post: 02-17-2019, 02:06 AM
  2. Replies: 10
    Last Post: 10-17-2018, 12:10 PM
  3. S9+ DCIM file only shows current photos that i took with the phone.
    Last Post: 10-14-2018, 04:04 AM
  4. Manage my phone Storage
    Last Post: 10-12-2018, 03:16 PM
  5. Manage my phone Storage
    Last Post: 10-12-2018, 10:18 AM
