1. recDNA's Avatar
    Does Light Flow led control app work with the multicolor led notification light?
    10-16-2018 03:39 PM
  2. Carrie Greicar's Avatar
    Yes it does. I have been using it for years.
    anon(3641385) and recDNA like this.
    10-16-2018 03:54 PM
  3. recDNA's Avatar
    Me too but I want to know if it specifically works on Note9.
    pizza_pablo likes this.
    10-19-2018 08:37 AM
  4. Carrie Greicar's Avatar
    I am currently using it on my note 9. It is working fine.
    recDNA likes this.
    10-19-2018 09:12 AM
  5. sweetypie31's Avatar
    It wouldn't work for correctly for me. It would change my charging led color from red to green and my call color from blue to green even when I set the color . Light manager pro works great.
    recDNA likes this.
    10-19-2018 12:38 PM
  6. verks's Avatar
    Works great on my Note9!
    10-26-2018 01:24 PM
  7. sulla1965's Avatar
    light manger is also a good LED app.
    10-26-2018 10:12 PM
  8. Carrie Greicar's Avatar
    I had it working on my first note 9, but I can't seem to get it to work right on my new one. It's driving me crazy
    11-02-2018 11:22 AM
  9. Carrie Greicar's Avatar
    Update. I fixed it. Just had to flip it on in the accessibility tab under settings
    11-02-2018 11:53 AM
  10. nuangel2's Avatar
    Yes it works
    11-06-2018 11:08 PM
  1. How service credit works
    By michaeljc70 in forum General Carrier Discussion
    Last Post: 12-24-2018, 11:16 AM
  2. Lock screen wont light up anymore when the phone is moved
    By Android Central Question in forum Moto X
    Last Post: 10-17-2018, 08:27 AM
  3. My flash light randomly turned on
    Last Post: 10-16-2018, 09:41 PM
  4. Moto X4 - how do I work the security number
    Last Post: 10-16-2018, 07:39 PM
  5. why does my verizon kyocera c6750 dont use mobile data
    Last Post: 10-16-2018, 04:16 PM
