1. preeble's Avatar
    Hi,
    I frequently tailgate with my SUV with a portable Bluetooth speaker. My issue is that whenever someone opens a door to the SUV, the car’s stereo goes on and my Note automatically connects to my car’s stereo (it’s a Land Rover) and stops streaming to my bluetooth speaker.
    I haven’t been able to change this behavior via configuration in the car, so I’m hoping there is some sort of android configuration or tool that I can employ. Any thoughts?
    I really don’t want to unpair my Note from the car every time I use the speaker.
    10-21-2018 07:26 PM
  2. B. Diddy's Avatar
    10-21-2018 08:13 PM
  3. anon(9918034)'s Avatar
    Hi,
    Go to Bluetooth then hit the 3 dots in the upper right corner. Select advanced and then toggle on dual audio. It allows the phone to be connected to 2 different Bluetooth devices for music play back.
    10-22-2018 02:40 AM
  4. preeble's Avatar
    Thanks - will try that.
    10-22-2018 08:16 AM
  5. anon(9918034)'s Avatar
    Did it work?
    10-23-2018 11:58 PM
  6. preeble's Avatar
    Haven’t tried yet - am out of town until the weekend. I will report back on Saturday.
    10-24-2018 09:51 AM
  7. preeble's Avatar
    it worked! Advanced settings of streaming to 2 devices prevented my car from cutting out my bluetooth speaker. Thanks all!
    B. Diddy and anon(9918034) like this.
    10-28-2018 11:39 AM
  8. EMGSM's Avatar
    Good to hear all worked out. You can't go wrong with AC forums.
    10-29-2018 09:05 PM
  9. anon(9918034)'s Avatar
    Glad it worked!!!
    11-01-2018 05:17 PM
  1. Replies: 6
    Last Post: 10-24-2018, 07:42 PM
  2. Using Sony Blu-Ray Playee (NSZ-GT1) with Sony Google TV (NSX-46GT1
    Last Post: 10-22-2018, 01:56 PM
  3. Replies: 1
    Last Post: 10-22-2018, 12:49 PM
  4. how can I remedy connectivity issues with nuu a3
    Last Post: 10-21-2018, 08:36 PM
  5. only audio with black screen after recording in any 3rd party app on note 2
    Last Post: 10-21-2018, 03:37 PM
