1. Uvuvwevwevwe Onyetenyevwe Ugwemubwem Ossas's Avatar
    I have seen Youtube videos on the Note9 and saw that their Note 9 has more than a day of battery life. However, mine only has 13 hours of battery life. Is this normal?
    10-22-2018 10:23 PM
  2. DanielLoreti's Avatar
    I'm getting 3 hours SOT
    10-22-2018 10:24 PM
  3. mustang7757's Avatar
    I would tell you how awesome my battery life is , but I had to check out your user name ...dammmmm 👍😁
    Knightmayre90 and erwaso like this.
    10-22-2018 10:33 PM
  4. TMavC5's Avatar
    Moderate use on my N9, phone off the charger 5:30am and is at 76% at 7:35pmpst.
    Jrome.brooks likes this.
    10-22-2018 10:35 PM
  5. anon(5719825)'s Avatar
    You don't say how you use your phone and what your display settings are like. Full brightness will result in less usage and watching videos will shorten your usage as well over the course of a day.
    I have a few phones I alternate between throughout the day so my usage may be hard to attain for others.
    I have a AT&T Note 9 that could barely last me a day with 1-2 hrs screen time if I was lucky. AT&T unlocked the phone for me and I put a T-Mobile sim in it and my battery life has been simply amazing. I am now getting 3 days standby with 4-6 hrs screen time depending upon usage. I had horrible signal on AT&T.
    I also have a T-Mobile Note 9 that is getting the same usage stats as the AT&T Note 9.
    10-22-2018 11:39 PM
  6. Knightmayre90's Avatar
    i have to say, as happy as i am with the phone, my battery life has never been that great. it always needs to charge by the evening. I plug it in during my drive to work and back so it gets topped up but it's never been anything special.
    10-23-2018 02:05 AM
  7. jeetu4444's Avatar
    1st thing is make sure u always start phone as fresh only backup contacts...
    switch off things like NFC..location...wifi and bluetooth scanning which is on by default....
    10-23-2018 08:29 AM
  8. DanielLoreti's Avatar
    How do you turn off background scan?
    10-23-2018 09:19 AM
  9. Jrome.brooks's Avatar
    Why are both note 9 different???
    10-23-2018 03:34 PM
  1. Where to buy authentic replacement batteries?
    By gcliff23 in forum LG V20
    Last Post: 09-24-2019, 11:06 AM
  2. Selling Note 9 for Pixel
    By RevePro in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 11-27-2018, 06:08 PM
  3. My CPU is at 100% level, draining battery, but no app appears to be active
    Last Post: 10-25-2018, 04:16 AM
  4. Replies: 1
    Last Post: 10-22-2018, 10:46 AM
  5. Why is my battery draining so fast after a batch of updates?
    Last Post: 10-22-2018, 01:54 AM
