1. mustang7757's Avatar
    Has that been removed ? Can't find to set power saving mode to turn on like at 15% or any other number.
    11-03-2018 10:39 AM
  2. Rukbat's Avatar
    That shouldn't be too much of a problem since, when the batery drops down to 40% you should either charge it or turn the phone off. Constantly dropping it down to 15%, with or without the battery saver coming into play, will kill the battery dead in a few months.
    Install GSam Battery Monitor and set the low alarm to 39% (and pick an alarm), so you'll know as the battery drops out of 40%.
    11-03-2018 11:22 AM
  3. mustang7757's Avatar
    I wait u til 5% to charge it but I didn't see option to kick battery power mode at any percentage I want it to come on , but I've been charging my devices for years like that never had issues whether it was correct or not.
    11-03-2018 11:27 AM
  4. Chromium 4's Avatar
    Pull your notification shade all the way down. Its located there.
    11-03-2018 11:50 PM
  5. mustang7757's Avatar
    I don't see where I can set it to come on at 25% automatic?
    11-03-2018 11:55 PM
  6. mhunter6378's Avatar
    If you use Good Lock, you can set a routine to do that.
    mustang7757 likes this.
    11-04-2018 06:42 AM
  7. mustang7757's Avatar
    Thank you, guess stock settings they took that away. This will work
    11-04-2018 07:40 AM
  1. Replies: 4
    Last Post: 11-09-2018, 08:06 PM
  2. Replies: 5
    Last Post: 11-03-2018, 06:43 PM
  3. Go to free mode not connecting
    Last Post: 11-03-2018, 12:38 PM
  4. I have restored factoy settings on LG F350K and now it is in Korean
    Last Post: 11-03-2018, 11:34 AM
  5. It says like a virus modem crash upload mode Wth is that??? (Galaxy A6+)
    Last Post: 11-03-2018, 11:24 AM
