12-20-2018 07:57 AM
268 ... 91011
tools
  1. cardboard60's Avatar
    The only reason I suggested to buy a Samsung Chromebook.
    Is because you have a Samsung phone.
    And about all your apps in your phone would work on the Samsung Chromebook
    Then you could wipe your phone and not put all the apps back on till you could see how the battery life is working.
    Hate your having problems.
    12-14-2018 12:10 PM
  2. mlbyanks11's Avatar
    Hate my having problems?? What??
    12-15-2018 10:00 AM
  3. mlbyanks11's Avatar
    Lol...even with your permission I wouldn't , dont have experience that way. Trust me if you were down the street I'd help without money or anything but it's hard to diagnose a problem when it's not in your hand .
    Dude my battery stopped draining. I restarted it and no more drain. I was in Canada and had great cell reception and that wasn't it. But whatever I did seems to be working. Hopefully it doesn't change next week lol.
    mustang7757 and Gray Area like this.
    12-15-2018 10:02 AM
  4. mustang7757's Avatar
    🤞I hope it stays like that
    You need to figure out what u did lol so incase next time .
    mlbyanks11 and Gray Area like this.
    12-15-2018 10:25 AM
  5. cardboard60's Avatar
    Battery problems.
    Hope it's fixed for you dude.
    12-15-2018 11:31 AM
  6. tadpoles's Avatar
    I can't complain. I took my phone off the charger yesterday morning. Have been using it normally and it has 47% battery left.
    Gray Area likes this.
    12-16-2018 06:08 PM
  7. deependra.rated.r.star's Avatar
    That's one of the major problem with Samsung based phones...
    12-16-2018 10:10 PM
  8. barathan.n's Avatar
    Disabling VoLTE will save alot of battery life.
    12-17-2018 06:20 AM
  9. mlbyanks11's Avatar
    Why would anyone not want to have HD voice and video calling?? Not happening but thanks anyway.
    12-17-2018 09:58 AM
  10. mlbyanks11's Avatar
    You're spot on.
    12-17-2018 09:58 AM
  11. mlbyanks11's Avatar
    Thanks for letting me know. How do you get such longevity?? Unlocked model?? I have Att 128gb model. I'm lucky if it lasts a day and it's frustrating. Sometimes I have to charge it 3 timea a day. I've disabled a ton of stuff too.
    12-18-2018 10:30 AM
  12. tadpoles's Avatar
    I had a 128GB AT&T model when the Note 9 first came out. I recall thinking battery life was meh, I sold it a while ago. I the unlocked 512GB seems to do much much much better on battery but I don't know why, both are setup pretty much the same.
    12-18-2018 02:15 PM
  13. mlbyanks11's Avatar
    Too late for me to swap it out. Unlocked model when I tried it out had signal issues. Samsung phones always have this problem.
    12-18-2018 04:15 PM
  14. EMGSM's Avatar
    I don't even look at SOT anymore. It gets me through the whole day. I'm happy with it.
    12-18-2018 09:04 PM
  15. mlbyanks11's Avatar
    Some folks like myself are less fortunate and don't always get that.
    12-20-2018 06:07 AM
  16. mlbyanks11's Avatar
    Mine is terrible even with heavy usage it gets hot and drains too quickly.Note 9 battery life.-screenshot_20181220-080904_settings.jpeg
    12-20-2018 07:10 AM
  17. Gayle Lynn's Avatar
    Heat is a sign of a problem with software.
    I was convinced of that after trouble with a phone. Factory reset and not restore, setup as new and had to ... carefully... install apps.
    Of course u was sure it was hardware, cable, piwer adapter. Even bought a 2nd identical phone, Blackberry DTEK60.
    Convinced me how software can be culprit. Temperature was hitting 44°C was draining very fast. Usually could leave it alone for days and be safe in a draw as backup. Except it hit zero overnight.
    Not every app is tested against every other, every user's phone is unique. All it takes sometimes is one mischievous.
    12-20-2018 07:39 AM
  18. mlbyanks11's Avatar
    i appreciate the assistance and suggestions but i've had 3 note 9 devices in similarity to the same issue. I use a lot of different apps and to factory reset which i've also done twice already is time consuming. To load my apps slowly is time consuming. Its a work phone as well so thats what makes it even tougher.
    12-20-2018 07:57 AM
268 ... 91011
  1. Using data while calling on note 8
    Last Post: 11-15-2018, 12:28 PM
  2. Is there a smartwatch that is compatible with a sprint note 9?
    Last Post: 11-12-2018, 06:50 PM
  3. Is there a smartwatch that is compatible with a sprint note 9?
    Last Post: 11-11-2018, 09:43 PM
  4. Battery icon
    Last Post: 11-11-2018, 10:35 AM
  5. Battery level has an x with a extension cord in it
    Last Post: 11-11-2018, 09:36 AM
