That doesn't like it makes sense though? Has to be another way to check what is keeping the CPU awake. Getting closer at least.
That's easy one to try , I'll see if I come up with anything else
I did but it was just as bad as before I had it. But thank you.you using a VPN ? I see little key in left hand corner of your last picture, turn that off also
go over this link also...but for testing purposes leave spen out lol
I am on the Pie and One UI beta.
I have noticed my battery life has taken a hit. Hopefully it gets better with updates.
Anyone know what this NLPHub is? I'm trying to restrict what apps think they need location acess.//uploads.tapatalk-cdn.com/20181211/7841b37a67ee8ea3f662a2ef41958997.jpg
It's that bad? Mine is about 7 sot and 1 day battery , I've been using my att sim to test it out since I always used my tmobile so overall not bad for me
Mine has definitely taken a hit. But, I've never gotten 7 hrs SoT or a day total on battery though. I was relatively close on total on battery time before the beta though.
But, I know it'll sort itself out.
Yeah definitely also keep the device maintenance close to 90% because it dips down to 80 % on pie . Here's my stats on pie
Left s pen out over night. It died and my battery didn't change. Woke up with 60 percent when charged up to 100 before bed.go over this link also...but for testing purposes leave spen out lol
S pen isn't the problem here. I can't figure out what it is. So frustrating and Samsung is clueless all they do is defer to device maintenance. Awful.
