1. JACKREACHER193's Avatar
    I can connect to Guest Wifi in work on my S7 not problem, but when I connect on my new Note 9 is comes up "Connection Not Private" - I've googled and done all the fixes they suggest (clearing cache, checking date/time) but still won't work.
    Wierdly when I look at the wifi settings on both devices they have different router addresses which I think may be the issue (security certificate hasn't been updated with new router address)?
    Any ideas?
    11-20-2018 04:17 AM
  2. amyf27's Avatar
    Any ideas?
    With mine, I pick no security certificate, and it works.
    11-20-2018 04:23 AM
  3. JACKREACHER193's Avatar
    thanks for reply! - how?
    11-20-2018 04:33 AM
  4. amyf27's Avatar
    It was just an option (on mine anyway), when attempting to connect to the work's wifi. They have a Guest and a regular Work wifi. Come to think of it, I think I was connecting to the Work / employees wifi. But I would think the Guest wifi doesn't require the security cert either, but I'm not sure. I think it depends on how your work sets them up.
    11-20-2018 04:35 AM
  5. JACKREACHER193's Avatar
    ok thx.
    11-20-2018 04:38 AM
  1. Problems texting in Vietnamese.
    Last Post: 11-20-2018, 01:05 PM
  2. Problem with Guest Wifi Connection
    Last Post: 11-20-2018, 04:05 AM
  3. Replies: 0
    Last Post: 11-20-2018, 02:15 AM
  4. Mate 20 Pro not connecting to bluetooth headset for calls
    By carleast in forum Ask a Question
    Last Post: 11-19-2018, 11:24 PM
