    I used to have a note 5, and even when it was plugged in and I was using it, it would still fast charge or at least charge to an extent. I recently purchased the note 9 and even though I'm using it, it has gone up maybe 3% in the last ten minutes. Is that normal..? It seems obnoxiously slow
    11-27-2018 12:16 AM
  2. sweetypie31's Avatar
    When I'm actively using my note 9 while it's on the charger it only charges slow if I plugged it up at 15% or lower. If my battery percent is higher it charges regularly .How low is the phone when you plug it in?
    11-27-2018 05:56 AM
  3. Gayle Lynn's Avatar
    After setting up and getting updates and apps installed good idea to wipe cache partition.
    If though you transferred or restored, that can cause problems.
    Assuming cable and plug are up to snuff and you don't have crazy background tasks running crazy. Facebook, big offender.
    11-27-2018 06:37 AM
  1. Samsung pay on Note 9 duos question
    By Freakster1 in forum Samsung Galaxy Note 9
    Last Post: 11-28-2018, 05:59 PM
  2. how to fix error while updating software
    Last Post: 11-26-2018, 10:19 PM
  3. What do I do to get colours back on all screens
    Last Post: 11-26-2018, 09:58 PM
  4. How to revert back to Android 8.1
    Last Post: 11-26-2018, 08:54 PM
  5. USB to RGB in car
    By marsneyb in forum General Help and How To
    Last Post: 11-26-2018, 07:25 PM
