1. Ak5hay's Avatar
    How to Enable battery fully charged notification on Samsung galaxy note 9 Android Oreo 8.1 or any Oreo 8.1 device?
    12-01-2018 03:16 PM
  2. Rukbat's Avatar
    I always use GSam Battery Monitor on any phone. You can set it for whatever maximum you want (you shouldn't charge the battery over about 90%), whatever minimum you want (you shouldn't discharge it below 40%) and over-temperature. You can also see what's using power.
    12-02-2018 01:45 PM
  3. OJsakila's Avatar
    My suggestion would be to download Samsungs LightFlow legacy from playstore
    You can customize all sorts of stuff for notifications...
    Beansr519 likes this.
    12-02-2018 02:14 PM
  1. Replies: 5
    Last Post: 12-02-2018, 04:46 PM
  2. My tablet is broken i would like to clone it what do I do
    Last Post: 12-01-2018, 08:20 PM
  3. Replies: 1
    Last Post: 12-01-2018, 08:10 PM
  4. Magicjack app rings while do not disturb ON and notifications OFF
    Last Post: 12-01-2018, 03:27 PM
