note 9 camera
Aaron Yap1
Active member
Jun 11, 2018
36
Guys , I tot note 9 camera suppose to be good at capturing bright lights and low lights . But when I capture this picture , the light bulb thingy above my subject is white , but in real life is orange. Why this happens and how to correct it?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,181
5,849
113
Did you use flash?
L0n3N1nja
3,629
4
I think you've got something changed in your settings, my Note doesn't have the yellow square like yours for where you click.
L0n3N1nja
3,629
4
Player with my settings, figured it out quick.
Disable Tracking AF if you want the exposure slider to appear when you tap on the screen.
SpookDroid
Ambassador
Jul 14, 2011
19,259
515
113
Well, that depends on where you want to focus and whether or not you've set the Auto-Scene or HDR options on/off. You're in Auto mode and that will usually over-expose night shots in order to avoid dark pictures. If you want more control over that you need to use the Pro mode and adjust color temperature,exposure, aperture, etc.
Aaron Yap1
Active member
Jun 11, 2018
36
pictures taken in auto mode during the day is already amazing , is there any point I should capture image using Manual mode during the day? I know night is better using manual but what about day time?
SpookDroid
Ambassador
Jul 14, 2011
19,259
515
113
Depends on your scenario. Even in bright light, though adequate, you might want to have better control over how your shot looks to avoid things like underexposure because you focused on a very bright spot. For instance, you can get better shots when the light source is behind your subject in manual than in auto (usually).
cyari6908
