Shop HP’s Memorial Day Sale:Save up to 61% on PCs and more!
  1. justme0485's Avatar
    is their anyway possible i could get this theme on my phone? I absolutely love it.. just Id def change the wallpaper..https://www.xda-developers.com/samsu...ung-galaxy-s8/
    I have tried downloading it.. but its' not showing up in my Samsung theme store. I might be doing it wrong.
    mustang7757 likes this.
    12-02-2018 04:13 PM
  2. L0n3N1nja's Avatar
    I've got the Verizon Note 9 and it worked flawless for me.
    Did you install the apk file after downloading it? Simply downloading the theme isn't enough for it to appear in the theme app.
    12-02-2018 05:12 PM
  3. justme0485's Avatar
    where do i find the apk file.. I am confused
    12-02-2018 05:57 PM
  4. mclarryjr's Avatar
    Just read the instructions and follow them
    How to install
    Open the Theme Store app and apply the default theme.
    Download and install the theme APK from the above link.
    Open the Theme Store app via the Wallpapers and Themes section in Settings.
    You should see the new Samsung Experience 10 theme here. Apply the trial and then restart your phone. Even though it says it’s a trial, it’s actually the full theme.
    12-02-2018 06:58 PM
  5. bassplayrguy's Avatar
    This is extremely confusing. It takes you to x da and when you download any of the Apk's, it asks you to use Nova or kwgt widgets. Can anyone help with instructions on how to make this work please?
    12-02-2018 06:58 PM
  6. mclarryjr's Avatar
    I click on any of these links and they download for me fine. Are you trying here?
    https://forum.xda-developers.com/sho...16&postcount=4
    12-02-2018 07:15 PM
  7. bassplayrguy's Avatar
    This is what opened. I'm not sure what to download. All of them? Need help installing a theme-screenshot_20181202-201835.jpeg
    12-02-2018 07:19 PM
  8. justme0485's Avatar
    so you have to go to default theme. then install the guilt icons from play store. and install the other thing to.. then download the theme.. then you go it! thanks so much!
    12-02-2018 07:23 PM
  9. bassplayrguy's Avatar
    The theme is the bottom download right?
    12-02-2018 07:34 PM
  10. ZOMMBIE1's Avatar
    Works good. And it's even better with Goodlock and the all black notifications too.
    12-02-2018 07:48 PM
  11. bassplayrguy's Avatar
    How do you get the icons to work? Are you using Nova?
    12-02-2018 08:07 PM
  12. Gary02468's Avatar
    Just a friendly reminder that on any internet forum, it's helpful and courteous to use an informative subject line. That way, people can tell at a glance which threads they want to read or contribute to, and they can more easily find their way back to specific threads later. Imagine if all the subject lines were like "I need help", "Has anyone seen this?", "Angry and frustrated", "I have a question", etc. They'd all be indistinguishable. A descriptive subject line may also get you faster and better replies.
    Manson79 and burrzoo like this.
    12-03-2018 06:35 AM
  13. BigMosely's Avatar
    I had little issue applying this theme BUT it keeps reverting my Navigation bar icons back to this themes icons. I have the custom Good Lock 2018/NavStar icons and every few minutes it keeps kicking it back to the theme icons even though I have the Navigation Bar icons set to do not use theme icons under Settings/Display/Navigation bar???
    12-03-2018 07:21 AM
  14. Golfdriver97's Avatar
    Mod note: Thread title changed to be more descriptive.
    12-03-2018 10:00 AM
  15. mustang7757's Avatar
    Nice theme , like it ....good find
    12-03-2018 10:18 AM
  1. Help please! Duplicates under settingd_apps
    Last Post: 12-05-2018, 04:06 PM
  2. hi, I lost my operating system, can you help me please ?
    Last Post: 12-05-2018, 12:10 PM
  3. Why the app shows update after the install instead of open button
    Last Post: 12-03-2018, 11:39 AM
  4. HELP! Odin not working
    Last Post: 12-02-2018, 07:23 PM
  5. After installing we 2012 the game was not start
    Last Post: 12-02-2018, 12:04 PM
