    There dn appear to be a simple fix in the settings for something like some earlier phones. I want to block others from seeing my phone number at time. Any help would greatly be appreciated!
    12-18-2018 02:54 PM
  2. bbgpsuser's Avatar
    1. Open the phone app
    2. Click the 3 dots and Settings
    3. Click on More Settings
    4. Click on "Show my caller ID"
    12-18-2018 03:42 PM
  3. jhimmel's Avatar
    Don't have that on my VZW Note
    12-18-2018 04:53 PM
  4. Gayle Lynn's Avatar
    Best I found with Google,
    Go into My Verizon, Profile & Settings, Manage Share Name ID.
    With that option, you can have the caller ID of the person you're calling display whatever you choose ie: Wireless, Private etc.
    12-18-2018 05:07 PM
  5. B. Diddy's Avatar
    Dial *67 before you make the call, which will block your Caller ID. https://forums.androidcentral.com/e?...token=HLtKCdm0
    thecomicbookandme likes this.
    12-20-2018 01:42 AM
  6. cscott44's Avatar
    You have to go to Verizon's webpage and request that your number be blocked for everyone. This is very inconvenient but is the only way I've found to block my number on the Note 9. On my Blackberry I can do this from the phone.
    12-20-2018 02:57 AM
  7. anon(5719825)'s Avatar
    Yes, you have to go to the Verizon website and set the option to block your caller ID for all calls. It's under the plan menu and then blocks.
    12-20-2018 03:24 AM
  8. Zin Stoss's Avatar
    Within the Phone app click on the three dots in the top right corner and go to settings.
    This will take you to "Call Settings" where you need to select Supplementary Services.
    Within Supplementary Services you'll find:
    - Show caller ID
    Tap on show caller ID and you'll see the option to "Hide number".
    BTW other options you'll find under Supplementary Services are:
    - Call forwarding
    - Call barring
    - Call waiting
    and
    - Fixed dialing numbers
    - Fi
    03-29-2021 11:38 AM
  1. Galaxy S7 - Intermittent ability to answer a call
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 12-18-2018, 09:51 PM
  2. How do i get to my clip board on my Android phone
    Last Post: 12-18-2018, 02:27 PM
  3. How do you remove the phone icon on top of messages?
    Last Post: 12-18-2018, 01:54 PM
  4. Burn In Issues - normal?
    By Hazard8989 in forum Samsung Galaxy S8 & S8+
    Last Post: 12-18-2018, 01:41 PM
  5. Galaxy S7 - Intermittent ability to answer a call
    Last Post: 12-18-2018, 01:17 PM
