1. felloffthetruck's Avatar
    Have this Belkin 10W wireless charger and the Note 9 feels like it gets hotter when using this charger vs the Samsung wireless 2018 wireless charger.
    Can a charger like this damage the Note 9's battery?
    Will a 10W wireless charger damage the Note 9's battery? Belkin-img_0434.jpg
    12-27-2018 08:12 AM
  2. donm527's Avatar
    It says Galaxy Note 8 so they are basically saying it's good to go. Some chargers are just going to run hot. That's why the Samsung's latest (the one I got with my 8 during pre-order promo) has fan built in to cool.
    12-27-2018 08:21 AM
  3. Kodak2's Avatar
    Belkin is a reliable brand and should not damage your phone. Only you can judge if it's getting excessively hot, but I would doubt it.
    12-27-2018 12:09 PM
  4. Gayle Lynn's Avatar
    Might want to read this overview. ZDnet is usually good.
    Best wireless chargers
    https://www.zdnet.com/pictures/best-...r-smart-watch/
    12-27-2018 01:01 PM
  5. strikeIII's Avatar
    I believe the Note 9 can handle up to 15W so you should be good. Even if you find a more powerful one the Note 9 will only allow what it can handle.
    12-27-2018 01:14 PM
  6. Gayle Lynn's Avatar
    I thought you needed 15W or more for fast charging.
    And my two Samsung wireless chargers are worth peace if mind. Anker otherwise but not for wireless.
    That Belkin unit came out before the S9's and Note 9 so it really may work of course but may not be latest standard or ideal.
    One unit I have is USBC on both ends, is Samsung with Fast Charging printed onto the stand.
    12-27-2018 05:45 PM
  7. CKwik240's Avatar
    You're phone will ultimately not be destroyed by it as your phone will probably have some safety mechanisms built in. But more heat will behave the battery a little faster. I'd go with the Samsung version as it has the built in fan.
    01-03-2019 01:33 AM
  1. Replies: 2
    Last Post: 12-27-2018, 07:57 AM
  2. Why is there no gallery on the zte bladespark
    By Sammysue1982 in forum General Help and How To
    Last Post: 12-27-2018, 06:04 AM
  3. Replies: 3
    Last Post: 12-27-2018, 05:16 AM
  4. How do I get out of the beta program
    Last Post: 12-27-2018, 04:59 AM
  5. Battery Drains While Screen Is On? Please Help.
    By Dankees in forum Samsung Galaxy Note 8
    Last Post: 12-26-2018, 09:33 PM
