01-06-2019 05:43 PM
29 12
tools
    I want to buy the Note 9, however I've heard that the FPS is little uncomfortable to reach and use. It's kinda a deal-breaker for me, cause I really care about the ergonomics of any phone. All I want to know how uncomfortable it is in terms of daily usage?
    12-31-2018 10:06 AM
  2. B. Diddy's Avatar
    I moved this to the Note9 forum for more specific traffic.
    12-31-2018 11:29 AM
  3. mustang7757's Avatar
    I find it comfortable, if you can check it out in the store see how you feel about it.
    kevinpleasants likes this.
    12-31-2018 11:32 AM
  4. keri2000's Avatar
    It's so much better than the Note 8 and you can swipe. It's fast and accurate. I have small hands but longer fingers than most women (they are as long as most mens fingers) so you should use one at the store to be sure.
    jimd1050, mustang7757 and Lefty724 like this.
    12-31-2018 12:11 PM
  5. Gayle Lynn's Avatar
    Better than on 8. Find my case makes it a breeze and easier too.
    Also the Iris + face is faster and better.
    jimd1050 and mustang7757 like this.
    12-31-2018 12:48 PM
  6. ajbrad71's Avatar
    my pointer finger sleeps like a baby. JK, like anything else you'll get use to it.
    BBSeattle likes this.
    12-31-2018 12:53 PM
  7. rju's Avatar
    I reconfigured 3x. Mine only works 50% or less of the times.
    12-31-2018 01:18 PM
  8. adegbenroagoro's Avatar
    Works well for me
    jimd1050 likes this.
    12-31-2018 01:39 PM
  9. jimd1050's Avatar
    As others have said, I used the "Iris Sensor" on my Note 8 because that was uncomfortable but I'm now using the FPS on my Note 9 because the repositioning has made that much of a difference for me! It's right where you'd expect it to be and even when I hold it in either hand!!!
    mustang7757 likes this.
    12-31-2018 02:12 PM
  10. note1note9's Avatar
    I keep reconfiguring mine, cause it doesn't work most of the time. which, I do not blame it on the phone because I have a weird combi of dry and sweaty fingers.
    however as one of them has said above, swiping seems to work more often for me than just placing my finger on the fingerprint sensor
    12-31-2018 02:44 PM
  11. Shaz Haque's Avatar
    Thankyou so much guys for your help. I guess I'm going for it since most you seem to have a positive opinion on it. Cheers.
    12-31-2018 07:40 PM
  12. L0n3N1nja's Avatar
    I find it no worse or better than the Note 8, I prefer the old school phones with the FPS on the front.
    BBSeattle and ViaCassian like this.
    12-31-2018 08:21 PM
  13. robpz16's Avatar
    I really like the placement, and find it fast and reliable. I'm a fan for sure.
    12-31-2018 08:41 PM
  14. msokad's Avatar
    I hated the placement on the Note 8 for that reason, I would use the PIN function to unlock phone or for Samsung Pay. Once I got the Note 9, I started using the FPS again.
    12-31-2018 09:19 PM
  15. robpz16's Avatar
    I've heard some folks complain that it's too close to the camera, but I don't feel this way at all. I love it. I went from a Pixel to an iPhone X, and now to a Note 9, and am surprised by how much I missed the FPS. Strange, actually.
    12-31-2018 09:35 PM
  16. berfles's Avatar
    No it isn't. The fingerprint scanner is the fastest way to unlock the phone from a raw speed perspective. It's almost instant when you touch the scanner, the Iris and face stuff takes a half second.
    01-01-2019 12:03 AM
  17. pizza_pablo's Avatar
    Comfort is subjective.
    I imagine hand size and finger length would play a big part.
    I can tell you that my FPS gets dirty and unresponsive easily. I clean it with alcohol or an eye glass wipe, often.
    Shaz Haque likes this.
    01-01-2019 12:13 AM
  18. neil74's Avatar
    It is ok and way better than the Note 8 and S8+. It is though (imo) not as comfortable as other options out there.
    01-01-2019 03:26 AM
  19. amyf27's Avatar
    To me, it's like anything else. You adapt. if it's on the front, on the back to the left, on the back centered. You adapt and adjust. I've had a lot of Samsungs and had the fingerprints in all of those positions, adapting to each without too much issue. I like where it is on the Note 9. I rarely ever have an issue reaching it or having it work on the first try, as needed.
    01-01-2019 04:52 AM
  20. mgbosshogg's Avatar
    It is what it is. I have zero issues with it. Just like the other countless devices I have owned with a fps.
    As said, you adapt.
    In combination with trusted places, face or iris unlock et al it works great.
    Personally I liked the fps on the front of my OP3 / T best.
    Think the underscreen one on the Note 10 will be pretty good also.
    01-01-2019 05:04 AM
  21. TonyHove's Avatar
    I've had the phone for exactly a month now. The fingerprint scanner is in a comfortable spot for me. You easily get used to it after a couple of days (especially if you are used to big phones).
    01-01-2019 09:01 AM
  22. Mr Segundus's Avatar
    My tiny hands could reach it without issues.
    01-01-2019 09:09 AM
  23. BBSeattle's Avatar
    Hated the location on the Note 8 but as with anything else, adapted and life went on. Not a life or death learning curve.
    Now having to relearn with the note 9... I'm sure I'll be fine... LOL
    Going from Blackberry to touch screen phones was a real learning curve. Did I just show my age?
    01-01-2019 10:22 AM
  24. DARK Vader777's Avatar
    The note 9 fingerprint sensor is even more comfortable using a Spigen Tough Armor case. You just slide right in, and very reactive. Sorry for the use of words. I find I use the Note 9 fingerprint sensor the most out of them all.
    01-01-2019 11:55 AM
  25. Iva_LadyDiCaprio98's Avatar
    I have no issues when it comes to using the Note 9 fingerprint sensor.
    mgbosshogg likes this.
    01-03-2019 07:16 AM
29 12
  1. forgot my knock code on lg g6 and fingerprint isn't allowed
    By Android Central Question in forum LG G6
    Last Post: 01-01-2019, 09:25 PM
  2. Replies: 1
    Last Post: 12-31-2018, 02:23 PM
  3. redeem in wrong account and how can i change that in the right account
    Last Post: 12-31-2018, 11:31 AM
  4. My Samsung galaxy grand prime pro is peeling of what should I do
    Last Post: 12-31-2018, 09:01 AM
  5. forgot my knock code on lg g6 and fingerprint isn't allowed
    Last Post: 12-31-2018, 07:54 AM
