1. Emmanuel Hernandez2's Avatar
    I notice a small difference between the volume of both speakers, the front speaker sounds a little lower than the speaker that is on the bottom of the phone ... I do not know if it is normal or the size of this are different... It's only a little difference, but exist... Any comments about that?
    01-03-2019 09:29 PM
  2. chanchan05's Avatar
    It's by design. The earpiece speaker is a tweeter, the bottom one is a woofer. They're meant to cover different frequencies.
    You can read about speaker types here: https://www.lifewire.com/all-about-speakers-4125129
    01-03-2019 10:57 PM
  3. mustang7757's Avatar
    I agree it's by design
    01-03-2019 11:49 PM
  4. Emmanuel Hernandez2's Avatar
    Thats very interesting... I really don't know that... this info makes me more calm about it...
    kct1975 and mustang7757 like this.
    01-04-2019 02:39 AM
  5. ZoosIsLoose's Avatar
    This is interesting to me because my top speaker is definitely louder and contains much of the treble response, but my bottom speaker is lower in volume and produces much of the bass response. It does make sense that this would be by design, but in terms of volume alone, my top speaker is louder.
    01-04-2019 06:56 PM
  6. chanchan05's Avatar
    The design is the top is the tweeter for treble and the bottom is the woofer for bass. As for loudness, it could also be dependent on the person themselves because everybody experiences hearing degradation as they age differently. Have you ran the adapt sound profiles? That also tells you what frequencies your hearing is starting to weaken in.
    01-05-2019 12:36 AM
  7. Emmanuel Hernandez2's Avatar
    That is interesting... Anyway, to me the bottom speaker is the one that sounds more loud... I don't know if I need send my phone to warranty for this reason.
    01-06-2019 02:31 PM
  8. bassplayrguy's Avatar
    No you do not.
    avs1121 likes this.
    01-06-2019 04:39 PM
  9. Emmanuel Hernandez2's Avatar
    No you do not.
    Thanks, I will keep it so...
    01-11-2019 01:42 AM
  1. Message sent is not readable and visible
    Last Post: 01-04-2019, 01:46 PM
  2. Difference in volume between both speakers
    Last Post: 01-04-2019, 05:29 AM
  3. Photos auto wiped out from Gallery and Google Photos
    Last Post: 01-03-2019, 04:07 PM
  4. Vedio pauses again and again in note 5
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 01-03-2019, 10:28 AM
  5. Vedio pauses again and again in note 5
