1. note1note9's Avatar
    When using Spotify to listen to music on my earphones and when I press the volume rocker once to increase the volume just a tiny bit, the volume will be increased a few times to the point I get shocked at how loud it becomes. It automatically does so randomly at times.
    Anyone else facing this issue?
    01-05-2019 12:51 PM
  2. B. Diddy's Avatar
    Is it only with Spotify, or with any media you're playing while using headphones? Are the headphones "Made for iPhone"?
    01-05-2019 06:50 PM
  3. note1note9's Avatar
    it's only with Spotify so far. Maybe I haven't noticed as i seldom use my earphones for other media.
    nope I'm using the AKG earphones that came with my phone.
    01-06-2019 07:46 AM
  4. B. Diddy's Avatar
    Try clearing the app cache/data for Spotify. Also, see if the problem happens with other headphones.
    01-06-2019 03:11 PM
  5. Javier P's Avatar
    I've also noticed that changing the volume for Spotify is quite different when I do it from the phone or from the headphones/Bluetooth device. I haven't found a way to fix this issue. It seems that changing the volume from the phone skips a couple of levels so I'm used to change the volume from the receiving device. Sorry, I know it's not much help
    01-06-2019 03:19 PM
  6. note1note9's Avatar
    It's okay
    I contacted customer service they told me to reinstall Spotify, which I did and so far the problem seems to be fixed.. fingers crossed
    B. Diddy likes this.
    01-07-2019 06:58 AM
  1. How to Change OS of a china made Huawei P20 Pro to any normal Android
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 01-05-2019, 07:03 PM
  2. Can you change the size of picture icons in OnePlus lockbox?
    By Android Central Question in forum OnePlus 6 & 6T
    Last Post: 01-05-2019, 06:02 PM
  3. Can you change the size of picture icons in OnePlus lockbox?
    Last Post: 01-05-2019, 06:39 AM
  4. How to Change OS of a china made Huawei P20 Pro to any normal Android
    Last Post: 01-05-2019, 06:12 AM
  5. Why do volume buttons not work when screen is off/locked.
    Last Post: 01-05-2019, 05:55 AM
