Save big with this Prime Day deal on theNVIDIA Shield TV
  1. Rkrohit Raghu's Avatar
    I discovered Phone battery drains from 90 to 65 % even if one not using the phone
    To solve just go to
    1. device maintenance -
    2. battery usage and then to
    3.android system
    4. just turn off this feature
    Allow background activity......
    It will reduces the battery drain to some extent.....
    It won't affect the device performance. I'm not sure about the qualcom varient just give it a try...
    Attached Thumbnails Reduce battery drain exynox note 9-smartselect_20190109-004251_device-maintenance.jpg   Reduce battery drain exynox note 9-smartselect_20190109-004321_settings.jpg   Reduce battery drain exynox note 9-smartselect_20190109-004307_settings.jpg
    01-08-2019 01:18 PM
  1. battery after updates.
    By Carlost88 in forum Nokia 7 Plus
    Last Post: 01-12-2019, 06:38 AM
  2. Note 9 Full backup... Help needed
    By Mathrania in forum Samsung Galaxy Note 9
    Last Post: 01-10-2019, 09:31 PM
  3. Note 8 Settings-System Update option missing?
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 01-09-2019, 08:24 AM
  4. Battery draining for fossil q explorist gen 3
    Last Post: 01-08-2019, 12:14 PM
  5. Samsung galaxy Note 4 dropped from 51% - 40 % to 0%
    By ismail kchit in forum Samsung Galaxy Note 4
    Last Post: 01-08-2019, 06:52 AM
