04-05-2019 02:52 AM
48 12
tools
  1. Gary02468's Avatar
    Anyone experience that? Maybe getting the Note 9 isn't a good idea.
    It's a great device when it works. I'd suggest that you buy it and use the camera extensively at the outset, so if it's broken for you, you can return it as defective within the time window where you can get a full refund. (For people who have the problem, it seems to follow them even if they replace the phone. It seems to depend in some random complex way on an interaction between the camera and the rest of your setup, but without any identifiable "rogue app" doing anything to cause it.)
    01-20-2019 09:34 AM
  2. jhimmel's Avatar
    So I haven't had any issues with my camera and had the device since launch. But you're saying I DO have an issue I just haven't experienced it yet? Which will all depend on how I use my camera? Not sure I'm buying that.
    I don't think it's fair to say "every" Note 9 has the issue including those who have yet to experience it but that's only because they haven't used the camera the same way as those experiencing the problem. Just a very tough sell to me.
    Whatever the capacity someone uses their camera and doesn't experience problems should not equate to they do have a problem but if they change how they were to use the camera then they will see a problem.
    That's just my 2 cents.
    Maybe NIZMOZ44 can inform you exactly how to reproduce the problem and test his theory?
    01-20-2019 09:45 AM
  3. Mathrania's Avatar
    Me and my wife has note 9 since the October now. No camera freezing or lagging so far. I use camera pretty much, and I REPEAT NO FREEZING SO FAR....
    thecomicbookandme likes this.
    01-20-2019 02:02 PM
  4. NIZMOZ44's Avatar
    It's a software fix that Samsung has been working on to resolve on the Note 9 with the SnapDragon and Sony Camera. That means all of them have it, it just not showing itself to you or others that haven't seen it.
    You don't have to buy it or not, but it's the facts. Read the Samsung community thread.
    01-21-2019 06:49 PM
  5. NIZMOZ44's Avatar
    All I did was put the camera in 4k, and recorded a video. It didn't happen till I was around 5-6 minutes in that it started misbehaving. It never did it on photos for me, only videos. Some people have it do it on photos.
    01-21-2019 06:51 PM
  6. jhimmel's Avatar
    I'll try it.
    01-21-2019 07:02 PM
  7. NIZMOZ44's Avatar
    Here is the video that I found that it was doing it on when I was in Vegas.
    https://photos.app.goo.gl/1fMQuxgr3ZFtb1We8
    01-21-2019 07:09 PM
  8. jhimmel's Avatar
    Pretty bad. How often would you see it? I just did back to back 10 minute 4K videos with no issues.
    01-21-2019 07:29 PM
  9. NIZMOZ44's Avatar
    That was the first time it ever did it. After that, I was able to duplicate it all the time in the video mode only when I was in 4k with the highest setting. I just switched it back down to 1080 I believe it was, and it worked fine from that point forward. If I can't record in 4k which the phone was designed for, why should I be paying $1300 for it. It was the high model too.
    01-21-2019 07:31 PM
  10. mustang7757's Avatar
    Will you get a note again 9 or next one?
    01-21-2019 08:10 PM
  11. NIZMOZ44's Avatar
    Waiting to see the 10. But most likely since I’ve owned every generation except the first two.
    01-21-2019 08:23 PM
  12. mustang7757's Avatar
    Cool ..yeah I own all except note 7 and 8 definitely like to see what the 10 brings
    01-21-2019 08:28 PM
  13. jhimmel's Avatar
    Glad I don't seem to have that bug, or maybe they fixed it.
    01-22-2019 06:52 AM
  14. edubb256's Avatar
    Hard to to tell if all of them have it. What you say is possible. But it is also possible that one (or more batches, but NOT all) of the camera sensors have a hardware fault and Samsung is working on a software fix to work around. With some types of hardware defects, it is possible to work around with a software or driver fix.
    I have had my Note 9 since September. I use the camera a lot and have not had a problem with it.
    01-22-2019 08:08 AM
  15. note1note9's Avatar
    hi all, I havent been using my camera that often, but recently around last week when I used my camera I noticed that theres a buzzing sound only when I zoom. I read about it and it seems the only way is to go to a Samsung shop to get it fixed?
    is there any other way around this?
    03-28-2019 05:52 AM
  16. jeetu4444's Avatar
    same problem here...while recording a video and u zoom in the 2nd camera start a buzzing sound and video is hazy...need to visit Samsung service store...iam sure they will not offer replacement but repair...
    03-28-2019 09:27 PM
  17. Russel Shouse's Avatar
    me and friend were at the zoo yesterday and when she used her note9 and tried to zoom, the screen got wavy, you could here the buzz that sounded like the aperture stuck or something.
    haven't seen it before, but it continued after a restart and even cache wipe.
    when we got home i couldn't reproduce it.
    i got our note9's on the same day, on release day.
    was glad to see a post about it.
    03-28-2019 09:44 PM
  18. note1note9's Avatar
    Yeah I just called up Samsung... so troublesome.. might just change my phone if they need me to wait too long
    03-29-2019 01:14 AM
  19. note1note9's Avatar
    It's a hardware issue. It needs to get fixed, cant be done with a restart of cache clear.
    When I got the phone since release day and was hearing issues with the camera not working properly I was then glad I didnt face any issue. Just my luck it came knocking on my door last week
    03-29-2019 01:16 AM
  20. jeetu4444's Avatar
    Will be taking the phone to Samsung service centre for camera problem and replacement of the 2nd camera... For buzzing sound and hazy camera... Will keep u guys updated
    03-30-2019 09:58 AM
  21. note1note9's Avatar
    Update: got my phone fixed. they changed the camera unit and I think they even changed my battery for free as well as its lasting much longer now.
    however through this I realised either the Samsung cloud or the Google drive back up didnt work very well as when restoring my apps they said there was an error....
    04-01-2019 01:18 AM
  22. jeetu4444's Avatar
    Great.. Iam gonna go to Samsung service centre soon... Hope they change my battery also for free
    But y they format the phone... As its a hardware issue... I can't afford to format my phone now... Will tell them not to....
    04-04-2019 09:44 AM
  23. note1note9's Avatar
    I asked if it was possible to not format they said no. I was left with no choice also....
    Better back up your phone first.
    04-05-2019 02:52 AM
48 12
  1. Replies: 2
    Last Post: 01-18-2019, 03:59 PM
  2. Instagram DM "typing indicator" issue
    Last Post: 01-18-2019, 03:37 AM
  3. Droid moto camera for iPhone?
    By Christa Garrett in forum Ask a Question
    Last Post: 01-17-2019, 10:57 PM
  4. Security issue, drop down menu accessible after locking device
    Last Post: 01-17-2019, 10:37 PM
