No, it won't open any of them. I have found someone with the same issue on XDA forums but short of a Factory reset, no joy.
Yeah I've done all that, from closing the app to wiping cache, it must be some setting somewhere or app.
I probably won't use that edge panel much anyway so I don't think I'll be doing a FR anytime soon unless other things start to go weird, its just the fact that it's not working that's all.
I hear you ..if I find anything let you know.
I'm having issue with button for silent only goes vibrate not silent .
You have the option for sound,vibrate and mute?
With volume control with buttons it go to vibrate not silent
I see, I set my volume buttons to media so that's all I use them for.
I just checked mine Mustang and it works - if you're talking about the button in the settings pull-down at the top. I tap it once and it goes to "Vibrate" - I tap it again, it goes to "Silent" - I tap it a third time and it comes back to "Sound"! (that's with the new AT&T Pie update as well)
No I'm talking about the volume button control wont go into silent just vibrate , toggle works in notifications panel
Was it like this on oreo Att?
I truly don't remember if any of my phones ever went silent from the volume button, now that you ask. If I thought that my Galaxy S7 Active might still have any semblance of a charge left in it, I'd pull it out of the box and try it. That was prior to my Note 8 however, so it's been boxed for a very long time and I think it was still running Nougat when I shut it down.
I haven't had this issue occur with mine. I'm currently on the standard Oreo with my Sprint Note 9. Have you checked for any updates with your phone 4 the system possibly for apps as well? There are like system apps and also the Google Play apps. Have you had any other issues with it besides the edge panel.
