02-04-2019 03:59 PM
36 12
tools
  1. mustang7757's Avatar
    HI guy's , I've encounter a problem
    I'm on the Att pie version
    When I select with the buttons to silent it only goes to vibrate but I can toggle silent on notifications panel toggle. Anyone else?
    02-02-2019 11:46 AM
  2. Jewels81's Avatar
    No issue here. And sorry I have no clue why your is having that issue but what does it do when you press the icon in menu in notification panel?
    mustang7757 likes this.
    02-02-2019 05:19 PM
  3. mustang7757's Avatar
    Icons no problem, but Jim verify his Att has same problem
    Jewels81 likes this.
    02-02-2019 07:32 PM
  4. mlbyanks11's Avatar
    I'm having issues where my sound for fb messenger text messages and emails completely silent. phone is not on silent everything turned up full volume.
    02-02-2019 08:29 PM
  5. mustang7757's Avatar
    Your on Att?
    02-02-2019 08:31 PM
  6. mlbyanks11's Avatar
    Yes I am. Can't figure out why either. So. Bizarre happened all of a sudden.
    Your on Att?
    02-02-2019 08:33 PM
  7. mustang7757's Avatar
    Have you tried restart?
    02-02-2019 08:34 PM
  8. mlbyanks11's Avatar
    4 times
    02-02-2019 08:38 PM
  9. mustang7757's Avatar
    4 times
    Maybe something up with Att update
    02-02-2019 08:42 PM
  10. anon(903870)'s Avatar
    Scaring me lol. Glad I haven't pulled the trigger yet ...
    02-02-2019 08:57 PM
  11. mustang7757's Avatar
    Come join the fun lol
    How you know if yours going to have issues unless you hit that update button.
    anon(903870) and pizza_pablo like this.
    02-02-2019 08:58 PM
  12. mustang7757's Avatar
    Is this happening on lock screen or when phone open ?
    02-02-2019 09:10 PM
  13. mlbyanks11's Avatar
    Both dont see how that makes a difference. My phone rings it plays my ringtones just text email and SMS message sounds are silent its so weird
    02-02-2019 09:45 PM
  14. Jewels81's Avatar
    Damn. I hope you find a fix.
    02-02-2019 10:53 PM
  15. mustang7757's Avatar
    Maybe try reset app preference in settings then apps ?
    02-02-2019 11:07 PM
  16. mustang7757's Avatar
    I hope so too..
    02-02-2019 11:07 PM
  17. TMavC5's Avatar
    Just tested mine. All is working on my end.
    02-03-2019 01:33 PM
  18. mustang7757's Avatar
    Ok and yours on Att ?
    So far me another guy have the issue .
    02-03-2019 02:44 PM
  19. sweetypie31's Avatar
    I just checked mine and it's the same way. I'm att as well. I wonder if it's an att thing.
    02-03-2019 07:30 PM
  20. mustang7757's Avatar
    I think it is ..
    02-03-2019 07:40 PM
  21. Fit24's Avatar
    Same here, but I thought it was like that before the update.
    02-03-2019 08:39 PM
  22. mustang7757's Avatar
    I'm starting to think probably was , I'm usually on T-Mobile or Unlocked firmware and didn't encounter this . But as soon T-mobile or Unlocked firmware becomes available I'll go to those.
    02-03-2019 08:41 PM
  23. TMavC5's Avatar
    Yes, AT&T Note 9
    02-03-2019 10:26 PM
  24. mustang7757's Avatar
    Yes, AT&T Note 9
    Your able to use the volume button to silence not vibration?
    02-03-2019 10:27 PM
  25. TMavC5's Avatar
    Yes, once I do that, I get volume option. If I want to silence it I just slide it down.
    02-03-2019 10:37 PM
36 12
  1. Where did Android Central go and what it has become
    By parout66 in forum General News & Discussion
    Last Post: 02-15-2019, 10:36 PM
  2. Why is my phone going off randomly
    Last Post: 02-03-2019, 11:20 PM
  3. Why does my incoming calls go to voicemail
    Last Post: 02-01-2019, 07:22 PM
  4. Replies: 2
    Last Post: 02-01-2019, 05:14 PM
  5. Replies: 0
    Last Post: 02-01-2019, 02:56 PM
