1. danielson2047's Avatar
    Battery saver has the option for disabling background refresh. Just wondering the difference between that and just turning off auto sync. Thanks!
    02-11-2019 09:24 AM
  2. mustang7757's Avatar
    Difference is can set individual instead of Auto syn off which is all
    02-11-2019 09:25 AM
  3. danielson2047's Avatar
    So is turning "disable background refresh" off the same as disabling background data?
    02-11-2019 10:22 AM
  4. mustang7757's Avatar
    Background refresh is not allowing that app to give notification or refresh it's content. Background data so when your on data instead of WiFi it can't refresh through your data connection its good if you don't have lot of data from your carrier .
    02-11-2019 10:26 AM
  1. Replies: 1
    Last Post: 02-11-2019, 10:28 AM
  2. How to sync my google photos from my computer to my samgsung note 4
    Last Post: 02-11-2019, 06:32 AM
  3. Disable/Remove extra home screen edge handle s9+
    By jun611 in forum Samsung Galaxy S9 & S9+
    Last Post: 02-11-2019, 06:24 AM
  4. Can you disable wave of alerts after switching off "Do not disturb"
    Last Post: 02-11-2019, 03:04 AM
