Jake R
What did you sideload?
I sideloaded the correct, current VZW version, and did receive the security update.
Firmware version now says N960USQU1CSAA?
That's because when Verizon updated to pie it was looking for Oreo build and you on CSAA. Now I'll provide you my link where you should get the SD update to go from CSAA to CSb3 then you should be ok.
https://forums.androidcentral.com/s...66-note-9-sd-card-sideloads-firmware-how.html
Thanks for the response. I'm kind of a newb when it comes to all this. Not even sure what odin is or how to use it? I apologize, if you could help break it down just a little for me that would be awesome. Thank you!
Sure , if you go to the link where I provided, you need to download the file CSAA to CSb3 and out on your SD card and go into recovery like you did with CSAA ...this method without Odin just SD Card
Sorry again, I don't know what to click on on the xda site for the sideload.
About 6 or 7 pages down be link to Google drive files
Does it have to be renamed to update.zip or just leave it the way it is?
Leave it the way it is
It worked. Thank you so much for your patience and help! Your a life saver!
So was the March security update for unlocked N9 on Verizon an April Fool's joke or what?
Unfortunately we just got March, think be some time before unlocked gets it, hope I'm wrong.I just got the March security update
Yes, I'm on April too.my Verizon note 9 has the April security update
Everytime you get a update.
What do you expect to gain.
A faster phone.
