    Where is the split screen feature on note9
    After up grade 2/16 can't locate it
    02-16-2019 04:48 PM
  2. mustang7757's Avatar
    go to recent apps , on the cards tap the icon you get a option
    02-16-2019 04:56 PM
  3. MsBlingberry's Avatar
    Hi. I checked my recent apps, still can't find the split screen option since the update. Anyone knows a fix?
    02-19-2019 12:31 PM
  4. mustang7757's Avatar
    Screen shot
    Attached Thumbnails Where is the split screen feature for note9-20190219_124456.jpg
    02-19-2019 12:45 PM
  5. MsBlingberry's Avatar
    Just tried it now, thanks a lot!!
    mustang7757 likes this.
    02-19-2019 12:51 PM
  6. mustang7757's Avatar
    Your welcome
    02-19-2019 12:54 PM
  1. Why my G-sensor doesn't work in the middle
    Last Post: 02-16-2019, 07:23 PM
  2. Galaxy s9+ how do you double lock phone with both PIN and fingerprint for double security?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 02-16-2019, 05:33 PM
  3. I want to see the last Text saved to my cliptray
    Last Post: 02-16-2019, 04:56 PM
  4. Is there a "total steps" widget for my gear?
    By Android Central Question in forum Android Apps
    Last Post: 02-16-2019, 04:28 PM
  5. Is there a "total steps" widget for my gear?
