1. gautamgammer's Avatar
    Samsung galaxy note 9 is fast charging only with the supplied charger if any other charger I use of same output or even more output it is not fast charging I tried with almost five different charger brands and the same cable.
    Can someone please tell me why?
    02-18-2019 03:53 AM
  2. Iva_LadyDiCaprio98's Avatar
    If you're using generic bricks, I would advise against it as that could cause damage to the phone's battery by overheating - but if you're using original fast charging bricks from other manufacturers, as long as it has the same voltage on the brick as the Samsung it should work. Any lower and it won't work
    jimd1050 and hrvoje.s like this.
    02-18-2019 07:24 AM
  3. Rukbat's Avatar
    The charger and phone "talk" to each other over the USB data lines to determine what the charger can supply and what the phone needs. If the charger isn't that type (and a plain 5 Volt charger, regardless of how many amps it supplies, isn't) it's only going to supply 5 Volts at the current the phone draws at 5 Volts - normal charging, not fast charging. (Look for a Qualcom Quickcharge 4 [or, at worst 3] charger.)
    02-18-2019 12:34 PM
  4. gautamgammer's Avatar
    I forgot to mention, I am using a Qualcomm certified charger it has dual USB charging ports one port is Qualcomm certified 3.0 and another port is they call it smart which determines how much volt and ampere is required by the phone and supplies accordingly still not fast charging. Another wall charger which I tried is off Apple iPad which is having same volt and point 1 ampere higher but still not fast charging.
    Thank you
    02-22-2019 01:00 AM
  5. Johnston212's Avatar
    That doesn't make any sense. Are you sure that it is not the cable?
    You really can't go wrong with Aukey or Anker.
    02-22-2019 01:22 AM
  6. Carrie Greicar's Avatar
    It's probably the cable. The cable has to be a fast charging cable. I have had these issues myself and switching cables did the trick.
    02-22-2019 06:43 AM
  7. stackberry369's Avatar
    I use regular charging
    02-22-2019 06:34 PM
  8. methodman89's Avatar
    This thread has so many misstatements I wouldn't know where to begin. And I don't wish to spend the time.
    To the op, use the oem cable and brick.
    02-22-2019 06:39 PM
  9. mfreeland's Avatar
    I use qualcomm QC 3.0 chargers and they work fine with my Note 9. I've literally never used the stock Samsung one...
    02-22-2019 11:06 PM
  1. How can I add the default new samsung clock widget on Samsung Note 9
    Last Post: 02-18-2019, 03:24 PM
  2. Problem with Alcatel apps
    Last Post: 02-18-2019, 05:39 AM
  3. Since I updated my Note 9 Android Pie, the Close All tab doesn't work properly
    Last Post: 02-18-2019, 03:44 AM
  4. Replies: 1
    Last Post: 02-18-2019, 12:52 AM
