Anyone notice that the edge panel is showing on the lock screen and it's bugging you?
I would like to actually use the edge panel feature, but don't think its access should be showing up on my lock screen, if I don't want it to. Don't see any way to adjust this... other than where you CAN edit to disable only a select few panels from lock screen. But you can't edit the 'edge panel handle' to hide the whole handle from lock screen.
