Note 9 phone sends emojis as question marks. Need help resolving this issue
  • Start date Start date
A
Android Central Question
Just got a new note 9 and all emojis sent are received as question marks. I'm able to receive others emojis however they are unable to see mine.
Happened to me. There's a setting to change that I forgot what it is. Changing something in the keyboard to automatic. Can't remember though.
Definitely see if you can find it , help anyone having this issue
This what I found...
Open messages. Go to settings.then more settings.then click text messages. Under input methods. Make sure it is set to automatic.
Has anyone found a solution to this issue? I'm on a different carrier and also do NOT have the option in Messages to change the input mode to automatic. There is no "input mode" option under Text Messages. I also don't have the "Message center" option that appears in the screen shot above, only "Manage SIM card messages." Can anyone help???
pmm09
