Note 9 SD card sideloads /firmware how to.
Hello, All. Thanks for this thread, and others. I've been scouring the internet about an update problem and it lead me here. I have an AT&T Note 9 that's stuck on the November security patch, and AT&T hasn't been able to help me. I've tried clearing the cache and restarting several times, restarting on its own many times, going into safe mode and checking...all of that stuff. The only thing I haven't tried is a factory reset, because I really don't want to go through the multi-hour process of backing everything up and reinstalling everything. (Why can't they just make an equivalent of Time Machine for Android??) Anyway, I know that you've helped folks out on here before. Can anyone help me get from software 8.1.0, Baseband version N960USQS1ARJA to Pie and the latest firmware? I know that I would need to get the December patch, at least, but I don't know what specific file I need to do that. Once I get it, I just put it on my SD card with the name update.zip, right? Does it need to be the only file on the card? I used to be so good at this...
Thanks, everyone! You're all incredible helpful!
I PM You
If you Odin to latest Android Pie 1CSD1 April patch
This one https://www.androidfilehost.com/?fid=1395089523397944212
And also need this Odin3_v3.13.1_3B_PatcheD https://www.androidfilehost.com/?fid=5862345805528067949 and only add BL, AP, CP, CSC , put HOME_CSC in slot CSC not CSC.TAR it will update your phone with no data wipe will just upgrade to latest Android Pie.
Also make sure you have Developer options in settings turn on USB debugging before doing Odin.
I was trying to load the sd card files here wouldn't let me , this is better thanks for this Ruben
Everything went fine for me. Thanks Ruben for the files and also thanks to both you and mustang7757 for always being willing to help the slow boogies like myself. Both of you are greatly appreciated.
I'm glad it did and your welcome
Ruben a great guy and pleasure to have here .
Glad to help ??????????????????
I have a Verizon Note 9, when I check for an update it says my last update was January 8th. And that I'm all up to date even after searching for an update. I did do the side load to One UI update in February. But, I haven't been able to update my phone since. Will the links above help me out?
I hope everything back to normal with the files I sent you?
Here Are Latest Firmware June Patch Odin Files All Universal on all Snapdragon Models USA
June Patch
AT&T And T-Mobile On Firmware SM-N960USQS1CSF1 Link: https://androidfilehost.com/?fid=6006931924117902468
MD5: 315bfdc0c24e778c9b091b4ed5949af5
Sprint On Firmware SM-N960USQS1CSF2 Link: https://www.androidfilehost.com/?fid=6006931924117904526
MD5: 3af6d175488d949ee085b0c7969237a8
Verizon On Firmware SM-N960USQS1CSF3 Link: https://www.androidfilehost.com/?fid=6006931924117905340
MD5: 8bece88ed11a3a5158b3215cbd301728
June Patch
Thanks for putting those up
ARH1 I was on ARG9 but went to arh1 slowly moving up but Samsung firmware science doesn't have a H1 to H2 option
Crusher
