1. frederickdawg's Avatar
    For some reason I got the attached message even though my S Pen wasn't detached and fully inserted. Hadn't been using my s pen prior either. Indicator that the s pen battery is finished?S pen battery low message.-screenshot_20190428-103801_samsung-experience-home.jpg
    04-28-2019 09:40 AM
  2. frederickdawg's Avatar
    For some reason I got the attached message even though my S Pen wasn't detached and fully inserted. Hadn't been using my s pen prior either. Indicator that the s pen battery is finished?Click image for larger version.
Name:	Screenshot_20190428-103801_Samsung Experience Home.jpg
    Withing a moment of that that battery went to 1%.
    I removed it from the folio case , removed pen and re- inserted and all issues went? Weird.
    04-28-2019 09:44 AM
  3. frederickdawg's Avatar
    I figured it out. It was the multiple magnets on my Unique London wallet folio case that was causing all these issues. No wonder it was so cheap on Ebay.
    04-29-2019 12:33 PM
  4. mustang7757's Avatar
    Wow, glad you figured it out .
    frederickdawg likes this.
    04-29-2019 12:42 PM
  5. pizza_pablo's Avatar
    Thanks for coming back and letting us know the cause!
    burrzoo likes this.
    04-29-2019 02:15 PM
  6. frederickdawg's Avatar
    No worries. My pleasure.
    Other anomalies are also occurring. For example when closing the case cover screen write would activate 50% of the time.
    I noticed that this folio case had a button size magnet on the front and back cover . It was put there for the latch. Note to stay away from those. In the past my folio cases has a discreet magnetic latch which didn't fold under or over the case hence no issues then.
    04-29-2019 02:26 PM
  7. pizza_pablo's Avatar
    I think it was the Motorola RAZR M, that a magnet case would light off car mode, which was a very restrictive operating mode. That gave folks all kinds of grief.
    04-29-2019 05:03 PM
  8. frederickdawg's Avatar
    Yes I dissected the case for educational purposes.
    S pen battery low message.-20190429_154743.jpgS pen battery low message.-screenshot_20190429-235553_gallery.jpg
    pizza_pablo and MsBlingberry like this.
    04-29-2019 10:56 PM
  9. adegbenroagoro's Avatar
    Way back when the Galaxy S3 came out I bought a case with a magnetic clasp. The phone went crazy. I've never used any since. In the past Samsung used to warn in the phone manual against using them.
    05-01-2019 04:32 AM
  10. frederickdawg's Avatar
    Indeed. On my note 8 I did have a leather folio wallet type case but the magnetic tabs were located on the edge of the strap. Meaning that there were no magnets on the actual back or front of case. That one worked ok.
    05-01-2019 06:59 AM
  1. How do you handle battery pull-when you can't pull the battery?
    By JnEricsonx in forum Samsung Galaxy Note 8
    Last Post: 05-02-2019, 10:22 PM
  2. SMS Backup + not backing up all messages anymore.
    By nuraman00 in forum Android Apps
    Last Post: 04-29-2019, 11:35 PM
  3. Why does my battery drain to fast while in my pocket
    Last Post: 04-28-2019, 06:20 AM
  4. How do i see and save a pinned message in my clip tray on my Android phone
    Last Post: 04-28-2019, 02:02 AM
  5. Messaging App with Pinch and Zoom & Keyboard
    By maggieo in forum Ask a Question
    Last Post: 04-27-2019, 11:58 PM
