1. Carrie Greicar's Avatar
    Does anyone know if there's a way to stop the screen from flickering/ flashing when you are making a call or have an incoming call?
    06-11-2019 11:55 AM
  2. mustang7757's Avatar
    Can see if you have animations on , try turning off in developer option or in settings
    06-11-2019 12:19 PM
  3. Carrie Greicar's Avatar
    Everything's off. Animation is set to none
    06-11-2019 12:28 PM
  4. mustang7757's Avatar
    So you never mess with animations or you just turn them off?
    06-11-2019 12:32 PM
  5. Carrie Greicar's Avatar
    I turn them off.
    06-11-2019 12:33 PM
  6. mustang7757's Avatar
    I turn them off.
    Ok , restart the phone see if everything ok now
    06-11-2019 12:33 PM
  7. Carrie Greicar's Avatar
    No I meant I turned them off when I first got the phone. It does it on my husband's note 9 too. I think it was new with pie because I don't recall the flicker before pie.
    06-11-2019 12:35 PM
  8. mustang7757's Avatar
    Hmm, I have to look into that
    There was some post here awhile back about this
    06-11-2019 12:41 PM
  9. Carrie Greicar's Avatar
    Found a solution. Animation needs to be set to .5 and not 0. Thanks for trying to help!
    mustang7757 likes this.
    06-11-2019 12:53 PM
  10. mustang7757's Avatar
    Oh , thought you completely turned it off lol
    Threw me off. Glad it's fixed
    06-11-2019 01:29 PM
  11. Carrie Greicar's Avatar
    I had it set to 0. But after you commented it got me thinking and I did some searching and found that others who had it set to 0 also had that problem but it was fixed when they put it back to .5 so I did that and it works!
    06-11-2019 01:33 PM
  12. mustang7757's Avatar
    Good , glad it's all sorted out
    06-11-2019 02:25 PM
  1. Why my 10org phone if someone calls me i never see and can't receive directly
    Last Post: 06-11-2019, 11:58 AM
  2. Replies: 1
    Last Post: 06-11-2019, 11:54 AM
  3. Galaxy 9 Note circle appears with person when I receive new emails
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 06-11-2019, 11:46 AM
  4. Galaxy 9 Note circle appears with person when I receive new emails
    Last Post: 06-11-2019, 11:16 AM
  5. Screen reader is narrating ALT and TITLE info when focus on the image
    Last Post: 06-11-2019, 08:58 AM
