My note 9 changed when it was recently updated.
Papabakes
When I receive a phone call now I have to drag my finger on the accept or decline button where before all I had to do is touch the button either way. I'd like to know what I can do to get it back to the way it was before.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
Accessibility >interaction and dexterity assistant menu toggle on , once you to the home screen it will show assistant chat like bubble just grab and drag to the top where a X will be to get rid of it
Gary Noonan
My phone got same problem after update today
Moving the buble around not relevant to swipe topic
Samsung has made phone hard to use for handicapped people and accessibility menu mow refers to device people can buy to control phone.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
"Moving bubble around not relevant to topic" :)
I guess you didn't understand what I'm saying.
In accessibility settings when you enable one touch instead of swipe ,it will leave a assistant floating app and to get rid of it to drag to the top and a X will appear to drop it , unless you like a floating accessibility icon floating around :)
Connert
1,071
16
38
Getting rid of the floating icon is not that simple and it comes back after a reboot. Here is a screen shot of the process from an S8 thread. Screenshot_20190626-062204.jpeg
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
actually I found better solution, I was thinking my s10+ before .
in the note 9
go to accesbilty 3 dots upper right corner turn of status notifications and turn one touch on , that's all very simple
Bo21
116
Turning off the "show notifications" only takes it out of the drop down bar, it doesn't keep the floating widget from showing up.
I have to kill the floating widget in apps by doing a force stop on accessibility after a restart. It stays gone until the next restart.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
Note 9 is different don't have floating widget, s10 does
Edit: unless you turn on assistant menu which u dont have to.
Bo21
116
To get the tap to answer, you have to turn on the assistant widget. I have not found another way yet on the Note 9. I am on a VZW Note 9.
Bo21
116
I thought Samsung pushed the same build to all the Carriers. I am on CSE5.
If I flashed the AT&T is it possible to get the tap to answer back in the Interaction and Dexterity menu under Answer Phone?
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
If you flash Att firmware your sim card will dictate what gets installed
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
I'm on the unlocked for the moment again
My screen shot
If you want the unlocked rom then your sim dont dictate what goes on20190626_194327.jpeg
Bo21
116
The OP was asking about the tap to answer option. You circled the easy on screen option that turns on the screen. That doesn't do the tap to answer.
I have those same options.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,481
6,091
113
It's in assistant menu , that's why I said scratch the 2nd circle
w8wca
