When I receive a phone call now I have to drag my finger on the accept or decline button where before all I had to do is touch the button either way. I'd like to know what I can do to get it back to the way it was before.
Accessibility >interaction and dexterity assistant menu toggle on , once you to the home screen it will show assistant chat like bubble just grab and drag to the top where a X will be to get rid of itWhen I receive a phone call now I have to drag my finger on the accept or decline button where before all I had to do is touch the button either way. I'd like to know what I can do to get it back to the way it was before.
My phone got same problem after update today
Moving the buble around not relevant to swipe topic
Samsung has made phone hard to use for handicapped people and accessibility menu mow refers to device people can buy to control phone.
Note 9 is different don't have floating widget, s10 doesTurning off the "show notifications" only takes it out of the drop down bar, it doesn't keep the floating widget from showing up.
I have to kill the floating widget in apps by doing a force stop on accessibility after a restart. It stays gone until the next restart.
To get the tap to answer, you have to turn on the assistant widget. I have not found another way yet on the Note 9. I am on a VZW Note 9.
If you flash Att firmware your sim card will dictate what gets installedI thought Samsung pushed the same build to all the Carriers. I am on CSE5.
If I flashed the AT&T is it possible to get the tap to answer back in the Interaction and Dexterity menu under Answer Phone?
I'm on the unlocked for the moment again
My screen shot
If you want the unlocked rom then your sim dont dictate what goes onView attachment 304809
The OP was asking about the tap to answer option. You circled the easy on screen option that turns on the screen. That doesn't do the tap to answer.
I have those same options.
