1. BuckyBadg's Avatar
    So, apparently since all the recent updates, when I tried to go to Safe Mode to Wipe the Cache Partition, it took me to Safe Mode, but did not show the usual blue screen. It showed the Home Screen and indicated Safe Mode in the lower left. The problem is, with this new Safe Mode screen, I do not know how to wipe the cache partition, then go to Reboot as I used to be able to do.
    Has anyone noticed this, and the change I’ve outlined above? Any suggestions would be greatly appreciated.
    07-09-2019 09:44 AM
  2. mustang7757's Avatar
    Safe mode doesn't take you to wipe cache.
    When you restart your phone before it goes on, hold same time vloume up and power button bixby this will take you to recovery to clear cache.
    pizza_pablo likes this.
    07-09-2019 10:46 AM
  3. BuckyBadg's Avatar
    You’re right. I interchanged Safe Mode with Recovery. Anyway, thanks.
    mustang7757 likes this.
    07-09-2019 07:01 PM
  4. mustang7757's Avatar
    No problem , your welcome!
    07-09-2019 07:03 PM
  5. BuckyBadg's Avatar
    Got on Recovery and deleted the cache. Thanks again.
    07-09-2019 08:17 PM
  6. mustang7757's Avatar
    Got on Recovery and deleted the cache. Thanks guys.
    No problem 👍
    07-10-2019 12:03 AM
  1. Nexus 6P Eatly Shutdown Problem
    Last Post: 07-08-2019, 12:46 PM
  2. Recobery after cache wipe
    Last Post: 07-08-2019, 12:03 PM
  3. Nexus 6P Early Shutdown Problem
    By Android Central Question in forum Nexus 6P
    Last Post: 07-08-2019, 05:22 AM
  4. Nexus 6P Early Shutdown Problem
    Last Post: 07-08-2019, 04:58 AM
  5. Nexus 6P Early Shutdown Problem
    Last Post: 07-08-2019, 04:55 AM
