WiFi calling in Quick Settings?
SpookDroid
Ambassador
Jul 14, 2011
19,298
553
113
I had it on mine and have it on the S10 so unless the carrier disabled it, you should be able to do so. Just expand the notification area and tap the menu button to access BUTTON ORDER. Any available options will show up on there.
BuckyBadg
133
Speaking of similar, is it possible to disable the repetitive and annoying notification: “WiFi calling settings updated”?
BuckyBadg
133
Once you set WiFi or cellular it should.
I think you misunderstood me. I've set it already and it still keeps sending me a notification. Otherwise, I wouldn't have asked :D.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,578
6,169
113
I see , gotcha
I'm not sure why it would keep giving notification once you choose . Do you have it set WiFi or cellular?
kirk781
