1. aweyrich's Avatar
    My AT&T Note 9 got its usual monthly software update a few days ago and it killed my bluetooth audio in car. It still pairs to the car and I can hear the other person - but they cannot hear me. So annoying. I have to turn speakerphone on and hold the phone to talk on it while driving - which I don't want to have to do. Anyone else have this issue with bluetooth since the update or know of a workaround?
    08-11-2019 12:44 PM
  2. justafew's Avatar
    Mine still works good in the car. Did you try to Unpair on your phone and remove the device in your car and then connect it again?
    08-11-2019 01:04 PM
  3. aweyrich's Avatar
    I did try that. Forgot to mention that. Still same result.
    08-11-2019 01:33 PM
  4. mustang7757's Avatar
    Have tried Andriod Auto ?
    08-11-2019 01:38 PM
  5. Ruben Ocasio's Avatar
    Unpair it then reboot your device, it also happen to me and that fixed it.
    mustang7757 likes this.
    08-11-2019 01:43 PM
  6. aweyrich's Avatar
    Ruben - THANK YOU - I had tried it in the opposite order - but this time I did it in the exact order that you did it and it worked - I appreciate you! I have a new job tomorrow and need it for my commute - so grateful!
    Ruben Ocasio likes this.
    08-11-2019 06:09 PM
  1. Samsung Note 10+ 5G _ Device locked.
    By bandofbrothers2112 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-11-2019, 07:17 PM
  2. My Samsung galaxy s8 showing All folders in left corner of gallerys each folder.
    Last Post: 08-11-2019, 03:57 PM
  3. My moto g6 turns off dolby audio in some apps
    By MageStorm in forum Ask a Question
    Last Post: 08-11-2019, 03:13 PM
  4. Note 10+ 5G Only Single Sim and Sd Card.
    Last Post: 08-11-2019, 01:23 PM
  5. Replies: 2
    Last Post: 08-11-2019, 12:23 PM
