1. DanielLoreti's Avatar
    I've always used WQHD+, but I was wondering how much extra battery usage would I get of I switched to FHD+ instead?
    08-25-2019 12:11 PM
  2. mustang7757's Avatar
    Extra half hour ,possible 1 hour more in HD
    08-25-2019 12:14 PM
  3. DanielLoreti's Avatar
    Ok thanks. I thought it was more significant then that.
    mustang7757 likes this.
    08-25-2019 12:27 PM
  4. mustang7757's Avatar
    Not in my test I've done on S10+
    DanielLoreti and ROE_HUNTER like this.
    08-25-2019 12:28 PM
  5. al3azim's Avatar
    I assume you mean in SOT, right?
    08-25-2019 01:29 PM
  6. mustang7757's Avatar
    Yes ..
    al3azim likes this.
    08-25-2019 03:19 PM
  7. cknobman's Avatar
    I've gone back and forth a few times.
    The difference has not been significant enough for me to want to keep the screen at HD+
    08-26-2019 07:38 AM
  1. Note 10+ Battery drain issue
    By Koolspy in forum Ask a Question
    Last Post: 08-26-2019, 11:54 AM
  2. What is the heart with a star in the middle notification icon?
    Last Post: 08-25-2019, 01:10 PM
  3. Similar objects function - how to get rid of it
    By Android Central Question in forum Huawei P20 & P20 Pro
    Last Post: 08-25-2019, 01:08 PM
  4. What is the heart with a star in the middle notification icon?
    Last Post: 08-25-2019, 10:40 AM
