Save big + get 3 months free! Sign up for ExpressVPN today
    Hi, I knew I can remove the shutter file before Lollipop. Now I can't remove it from my Note 9. It's so annoying when I took pictures friends gathering, especially in the restaurants. Mute all function just a temporary solution, often I forgot to switch back to normal. Anyone successfully remove the file to disable the camera shutter sound? XDA forum so far no one knows the methods because I posted this issue and no answer.
    11-10-2019 06:39 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist
    https://forums.androidcentral.com/sh...d.php?t=409154
    11-10-2019 06:58 PM
  3. mustang7757's Avatar
    Should be in settings of the camera app
    11-10-2019 06:59 PM
  4. mib1800's Avatar
    Use the Routine app to set the phone to vibrate when in camera. It will auto reverse to previous sound profile when you close camera app
    11-10-2019 08:40 PM
  5. Brad Bilger's Avatar
    Wasn't it also carrier dependent? I use AT&T and I can just turn the shutter sounds off. I do know that other Carriers disallow that. Privacy concerns or something like that.
    11-11-2019 08:10 PM
  6. mustang7757's Avatar
    It's possible , carriers can do that
    11-11-2019 08:27 PM
  7. debdroid1a's Avatar
    I thought it was also some countries that didn't allow it.
    My phone is on silent since I wear my watch a lot. However I'm on Tmobile, usa, locked, and it did allow me to silence mine.
    I opened the camera, chose settings, shutter sounds and silent toggle.
    Attached Thumbnails Samsung Note 9 shutter sound can't disable permanently-9955.jpg
    11-16-2019 08:47 PM
  1. Are All USB-C Earbuds/Earphones Compatible with the Note 10+?
    By CemicSuns in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 12-03-2019, 10:08 PM
  2. Common solutions to Note 10 & 10+ problems
    By RickMG in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-11-2019, 07:51 PM
  3. My gallery in the Samsung S10+ is tiled-I want to change this
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 11-11-2019, 01:34 PM
  4. Lagging ATT Note 10+
    By BigCrimsonTX in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-10-2019, 05:44 PM
  5. samsung s7edge rear glass had broken due to battery swolen..
    Last Post: 11-10-2019, 04:35 PM
