As in the title, I have a wallet/case for my note 9. There seems to be 3 horizontal scuff marks across the screen (which line up with the seems of the case) and when I slide my finger across them it seems to lose touch sensitivty. If I was scrolling it would stop or at worst think I tapped the screen and open a link/press a key.
Is there any way to fix this problem? Its not easily seen unless the screen is a little oily and then you can see 3 very distinct lines where I am having the problem
12-07-2019 11:02 PM
