Hey all,
I bought my galaxy note 9 (international) back in October 2018. Got android 9 update as soon as I set up the device. I was in France and had been receiving software updates regularly. Then, I moved to Turkey in June 2019, received 2 or may be 3 updates there. I received the last software update in October 2019. I left Turkey in February 2020 and now I am in Belgium. I haven't received any software update after October 2019. Here is what I have tried so far:
>Manually checking for updates in the setting>software update
>Samsung smart switch which always says your software is up to date SI5(LUX)
>Contacted Samsung support from the app, they told me my phone is Singapore origin. I talked with Samsung support Singapore and they said that Samsung has released the update in Singapore long ago. Since I am out of Singapore and using other sim carrier so I will receive the update eventually (not really sure when).
>Using VPN proxy and setting it to many other countries just to check if that works.
>Factory data reset (I read somewhere it also works sometimes)
>Using my Turkish and Pakistani simcard (on international roaming) to see if that works.
I have tried all above things after clearing cache partition and clearing the data of Samsung store.
Is there anyone who can help me with this? or who has been facing the same problem?
