I've been on the fence between the Edge and the Note 4, and there's one thing about the Edge that I don't think I'll be able to get past, unless there's a solution... It's nearly impossible to hold when using it as a camera (securely at least) without inadvertently touching the camera controls along the edge. Playing with it in the store, I found it very hard to have a secure grip on the thing when holding it sideways without accidentally hitting the shutter button.
Is there any option to just move the camera controls down to the screen and disable the edge controls?
(I would also recommend to try using this phone as a camera before buying it. It's the one big problem I've found when playing around with it, and I think it may steer me over to the Note 4.)
