1. Sammytheorangutan's Avatar
    Well, 2 questions so far. Got my Edge about 4 hours ago. I've been customizing it (installing apps, moving icons, etc) and I have 2 questions. First, is there any way to swap icons on the Edge screen (2nd screen? thumb screen?)? For example, it has an icon for the generic web browser. I use Firefox so I'd rather have the FF icon instead of the generic one (Samsung/Sprints browser). I don't want a bunch of icons that will just muddy the waters. Second, before I got this, I read that you can customize the Google voice activated search thing (no idea what the official name is or I'd search for it) so instead of having to say "Ok, Google" (which sounds dumb), you can say whatever you like such as "Wake up, minion!" or the like. Anyone know how to customize that or what I can search for?
    Great phone so far but a heck of a learning curve, even from my previous S4 (which I thought was a great device). Lots of things to move, check, uncheck, etc. Good thing I'm on holiday.
    11-20-2014 10:19 PM
  2. blitz118's Avatar
    To customized the edge panel select the star at the top of the panel, then you can drag and drop apps on the panel. When your done select done. I don't use Google voice, but I'm sure one of the other forum members can help you with it.
    11-21-2014 12:10 AM
  3. joganjani's Avatar
    How do you customize the second Fav panel? This is in AT&T version. I do not seem to edit anything on that one. Only I can unselect it.
    11-21-2014 12:58 AM
  4. blitz118's Avatar
    It looks like you cannot edit that panel on the ATT version. I was trying to edit it last night, and I couldn't.
    11-21-2014 07:11 AM
  5. cgooge14's Avatar
    I can't edit that second panel either...also on At&t..
    11-21-2014 09:42 AM
  6. Sammytheorangutan's Avatar
    I have the Sprint version. It doesn't seem I can edit that, either. What about changing the voice commands on the Google thing?
    11-23-2014 07:11 AM
  1. How can I repair the back camera lens on my NOTE EDGE?
    By Jeniffer Davis in forum Samsung Galaxy Note Edge
    Last Post: 05-17-2015, 01:59 PM
  2. Verizon G2 insurance question
    By 2001400ex in forum LG G2
    Last Post: 11-22-2014, 12:17 PM
  3. Replies: 2
    Last Post: 11-22-2014, 11:59 AM
  4. Replies: 2
    Last Post: 11-21-2014, 05:29 AM
  5. Google Maps question (ver 8.4.1)
    By wms3 in forum AT&T Galaxy S III
    Last Post: 11-20-2014, 10:15 PM
