1. boriqua2000's Avatar
    is there a way to not get notification pops up in the edge screen? every time I get a text message the edge screen lights up with a New Message notification. how do I turn that off?
    11-21-2014 01:50 AM
  2. NotAnAppleGuy's Avatar
    I noticed that it is not many customization options for the edge screen. I for one am trying to figure out how to get the battery percentage to show up on that screen.
    11-21-2014 05:24 AM
  3. blitz118's Avatar
    I noticed that it is not many customization. options for the edge screen. I for one am trying to figure out how to get the battery percentage to show up on that screen.
    I think you will have to add a battery app to the edge panel. At this time the panel is kind of limited to what you can do to it.
    NotAnAppleGuy likes this.
    11-21-2014 07:14 AM
  4. SHIVA77's Avatar
    you may consider swapping your Edge for a Note 4. the notification panel is one of the main features of the Edge.
    11-21-2014 11:14 AM
  5. NotAnAppleGuy's Avatar
    I'm sticking with it. Never had a Note before so its a serious learning curve for me. My coworker on the other hand has a Note 4 and she multitasks on that thing like we breathe air. Effortlessly. ..
    11-21-2014 01:19 PM
  1. Metal Band & Notification Issues?
    By racquetballer in forum Moto 360
    Last Post: 11-23-2014, 02:23 AM
  2. how to put note 4 clock back on home screen
    By Searcher1 in forum General Help and How To
    Last Post: 11-21-2014, 02:19 PM
  3. HELP: "None" Screen lock GONE
    By LezCronut in forum Android 5.0 Lollipop
    Last Post: 11-21-2014, 01:43 AM
  4. Replies: 0
    Last Post: 11-21-2014, 01:38 AM
  5. How to play DVD in PC Optical drive over LAN on N7 13?
    By Machinist60 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-21-2014, 12:33 AM
