1. Pracis's Avatar
    I finally got the phone this past week! Great phone and all... but for some reason, the phone either keeps freezing or restarting. For the most part, it seems to happen when I use the Night Clock. I've done a factory reset and kept the apps to a minimum. But it's still happening.
    Is there anything else that I can do? I'm wondering if the phone might be faulty?
    11-22-2014 01:28 PM
  2. blitz118's Avatar
    I have the ATT version, and I also use the night clock, and I've had no crashing issues. The phone has been rock solid so far.
    11-22-2014 01:35 PM
  3. Pracis's Avatar
    blitz: thanks for the reply..
    First.. what software do you have installed? I've also got the ATT also.
    11-22-2014 01:40 PM
  4. blitz118's Avatar
    When you say software do you mean apps? If so I don't have a lot installed. I only install apps that I need. I'm not into installing hundreds of apps that I'm not going to use.
    11-22-2014 01:46 PM
  5. Pracis's Avatar
    Yeah.
    I'm wondering if it's the launcher that I'm using... seems like the only thing that I can think of that might have an issue with how the edge is built? I don't know.. :/
    11-22-2014 01:49 PM
  6. blitz118's Avatar
    Yeah.
    I'm not using any launcher. Try removing the launcher and see if it still crashes.
    11-22-2014 02:08 PM
  7. cgooge14's Avatar
    I am on AT&T with Nova Launcher installed and have had no crashes..
    11-22-2014 06:22 PM
  1. Microphone issues after Lollipop OTA
    By Neil Begin in forum Google Nexus 5
    Last Post: 05-05-2016, 03:52 AM
  2. File Naming Issues...
    By Stwutter in forum Sony Xperia Z3
    Last Post: 01-28-2015, 04:15 AM
  3. Use Verizon Message+ or Hangouts
    By NickA in forum Google Nexus 6
    Last Post: 11-22-2014, 01:26 PM
  4. Replies: 0
    Last Post: 11-22-2014, 01:18 PM
  5. Multiple Contacts with same phone number
    By merlin266 in forum Samsung Galaxy S4
    Last Post: 11-22-2014, 12:04 PM
