01-11-2015 12:08 AM
45 12
tools
  1. clitrenta's Avatar
    Yes. It works perfectly in Night Mode, but otherwise you have to do a quick turn with the phone to get the orientation to work as it should otherwise. It's not a deal breaker in anyway, and hopefully they will address it as a "bug fix" in a future update, but for now 21st Now has helped me to figure out how to make it work.
    Now you would think that those testing it might have looked at it and said to themselves, "that should go the other way". Guess not.
    11-27-2014 05:50 PM
  2. 21stNow's Avatar
    I think that Samsung decided to have the sidebar scrolling in a way that could be read while a person is actively using the phone. They didn't think that people would want to run the battery down by sitting there watching stock quotes all day (as I do).
    The issue here is that the main screen and the edge screen are all one screen with two different displays. If they had set up the main screen and the edge screen as two different screens, the orientation issue wouldn't be a big deal, as we could set the edge screen to rotate 180 degrees and leave the main screen in the upright position or even lock it. I prefer to lock my phone's display to portrait for normal use but can't if I want the edge screen to rotate when I close the cover.
    11-28-2014 12:14 AM
  3. Sammytheorangutan's Avatar
    When I swipe the edge with the screen turned off, it turns on the main screen. Occasionally, it'll just light up the edge screen but if I move the phone in any direction so much as a millimeter, it turns the main screen on. I'd like to see the clock, etc on the edge all by itself. I'm not worried about draining the battery. And, no matter what I do, I can't get the edge screen to rotate (other than the night clock).
    11-30-2014 03:55 AM
  4. DAS's Avatar
    You have make sure the devices main screen rotation is activated, along with 180° box checked under managed panels.
    Move to a panel like the news feed and then turn the phone upside down so that Samsung is at the bottom and then turn it back again. You will see the entire display rotate, and your Edge panel will be in desired orientation.
    I will try to post a video if this app will allow it.
    11-30-2014 07:24 AM
  5. 21stNow's Avatar
    If you are trying to just wake up the edge screen, are you swiping left then right on the edge screen only? The edge screen needs to be facing you for this command. Don't drag your finger across the entire length of the edge screen, just over the middle section. It wakes up in about 1-2 seconds.
    11-30-2014 12:04 PM
  6. Sammytheorangutan's Avatar
    I'm doing all that and finally got the edge screen to rotate (!) it keeps waking the entire phone up. Not trying to do that. Is there a sensitivity adjustment I can change? It won't wake up just moving the phone around unless the edge screen is lit.
    11-30-2014 03:25 PM
  7. 21stNow's Avatar
    You will probably have to wake the phone up to get the edge screen to rotate unless you use your phone upside down on a regular basis. Did you try to wake up the edge screen the way that I mentioned in my previous post (#30)?
    11-30-2014 04:49 PM
  8. Sammytheorangutan's Avatar
    Yup. All it does is wake up the entire phone. If the night screen is set to "ON", it'll just activate that but you can only set the night screen to come on for a total of 12 hours, not 24. (I have it come on for the 12 hours I might be sleeping since I use the phone as an alarm clock.) I'm not going to go into the settings and change the on/off times of the night screen every day.
    11-30-2014 05:26 PM
  9. 21stNow's Avatar
    I have my night screen set to "off". However, when I swipe left then right on the edge screen, I get a clock, scrolling stock quotes and scrolling headlines on the edge screen. The main screen stays dark.
    I'll try to do a video of this tomorrow at work so we can see if we are talking about the same thing.
    11-30-2014 10:01 PM
  10. DAS's Avatar
    I have my night mode set to 10pm - 7am (probably TMI). However, if I swipe left to right at anytime the scrolling headlines begin, and my main screen stays dark.
    11-30-2014 10:12 PM
  11. Sammytheorangutan's Avatar
    Problem solved. Turns out it was a conflict with an app. Disabled the app and it works fine.
    Any way to control the content of this? I just want to see the time and date. When it first comes on, it shows: temp/brief weather description (i.e. "some clouds")...time...date then, as it starts to scroll, it shows the Accuweather icon with the same brief weather description (I already saw it...I don't need to see it again ) followed by the Lookout icon and the last Lookout process (i.e. "scan finished: blahblahblah app is safe"). I'm good with the temp, time and date. I don't need the rest.
    12-01-2014 07:27 PM
  12. DAS's Avatar
    The contents are reflective of the panels you've selected in settings. In order to see less info you'd have to select less panels.
    12-01-2014 09:22 PM
  13. Sammytheorangutan's Avatar
    I only have 2 panels selected and neither of them have Lookout checked. I can get rid of the weather (but put it back). I'd still like to get rid of Lookout but not if it means disabling the app.
    12-01-2014 11:11 PM
  14. paradroid's Avatar
    I still don't have this. Must be the Masscons!
    If I check the 180 box in manage panels, have rotation on. All wedge messages and notification, show upside down with phone flat.
    if I uncheck the 180 box everything comes in right side up accept text message notifications which show upside down with the phone laying flat and the wedge pointed toward me. Is this what you get or do your text message notifications also come in right side up.
    It would be a plus to read text messages easily when the phone is laid down flat, wedge toward me.
    12-03-2014 04:19 PM
  15. Sammytheorangutan's Avatar
    Put the phone to sleep then swipe left/right on the edge screen to turn it on (just the edge screen). If it's upside down, tilt the phone so the "top" is now the "bottom" then level it back out. The edge screen should flip over.
    12-03-2014 05:32 PM
  16. 21stNow's Avatar
    Check this out and let me know if it helps.
    DAS and paradroid like this.
    12-03-2014 09:36 PM
  17. DAS's Avatar
    That is so nice of you to do. This one video will help so many people. I like you're flip case. I can't find one anywhere in Texas, and they are on backorder with Samsung.
    By the way, nice watch :-)
    12-03-2014 10:15 PM
  18. 21stNow's Avatar
    Thanks! I got my case from AT&T, but I had to look around the store for it. The people that tried to help me weren't quite sure of what I was looking for.
    12-03-2014 10:53 PM
  19. paradroid's Avatar
    I think that did it. I had a text come in right side up. thanks.
    Kind of strange to have to flip the phone upside down to get text to show the right way when laying flat.
    12-04-2014 12:01 PM
  20. vladio007's Avatar
    I can't figure out how to change what is displayed. I selected all and none of the panels and nothing changed. Initially, there was an icon of an app that would scroll off with the clock but, since I didn't use the app, I uninstalled it to see what would happen and now just the clock is displayed. It doesn't scroll now either.
    01-11-2015 12:08 AM
45 12
  1. T mobile Note Edge Back order
    By kimberle2008 in forum Samsung Galaxy Note Edge
    Last Post: 01-01-2015, 03:42 PM
  2. advice for a slim but all edge case
    By thoir in forum Samsung Galaxy Tab S 10.5
    Last Post: 11-28-2014, 03:43 PM
  3. Anyone have issues with Edge crashing or restarting?
    By Pracis in forum Samsung Galaxy Note Edge
    Last Post: 11-22-2014, 05:22 PM
  4. Dust around the edges?
    By Tactical Squirrel in forum Samsung Galaxy S5
    Last Post: 11-22-2014, 06:01 AM
  5. How to turn off notification pop up in Edge screen?
    By boriqua2000 in forum Samsung Galaxy Note Edge
    Last Post: 11-21-2014, 12:19 PM
