Maybe because they feel it wasn't worth the cost? Aren't as blown away by it as imagined?
Just curious...
Just curious...
Just curious...
Okay. I have both the edge and note 4 and debating whether or not to return the edge and go back to the Note 4
My main question is that in terms of multitasking, does the edge screen offer anything of value over the Note 4 when one can just use the multitasking key on the Note 4?
No, I will not be returnuing it. I use the edge panel to access my favorites quickly, and the phone is unique and there is nothing out there like it. I've posted multiple videos showing the features of the phone.If you do not like the phone then return it.
Thinking about switching to the standard Note 4. I have not found any extra value to the side bar yet other than it looks cool.
Exactly. I switched back and am glad that I did.
I prefer the Note 4's larger screen, better battery life and ergonomics.
