1. chgomaverick's Avatar
    On my Mac, both. KIES and ANDROID FILE TRANSFER don't work. Don't recognize device.
    Is there another way to transfer files between my Edge (4.4.4) and Macbook pro (10.9.4)?
    Any help appreciated!
    01-04-2015 07:44 PM
  2. hallux's Avatar
    Pair through Bluetooth and transfer them that way?
    01-04-2015 08:58 PM
  3. glidersgalore's Avatar
    Use Drop Box
    01-07-2015 04:52 PM
  4. whtchdr's Avatar
    Yep, use drop box or one drive.
    01-10-2015 12:14 AM
  5. joganjani's Avatar
    Did you have keys installed in the past? If you did, download uninstaller and uninstall it. AFT will work fine after that.
    01-10-2015 12:25 AM
  6. Rukbat's Avatar
    WiFi File Transfer should also work (since all it needs on the Mac side is a web browser).
    01-10-2015 06:00 PM
  7. Hghlndr's Avatar
    Hey try Samsung SideSync 3.0 I happened to be reading in this forum (have Note 3) and saw your question. Comments are correct about Kies and AFT. After trying SideSync (had to delete AFT too) it works seemlessly on my MacBook Pro 10.10 Good luck
    01-16-2015 01:24 AM
  1. Why isn't my phone connecting to my data network (G900F)?
    By unbiasly in forum Samsung Galaxy S5
    Last Post: 01-07-2015, 01:52 AM
  2. Best way to purchase for Tmo Use
    By Dan Owen1 in forum Google Nexus 6
    Last Post: 01-07-2015, 12:40 AM
  3. How do I restore my Android system to my next7p12?
    By viperbird in forum Ask a Question
    Last Post: 01-04-2015, 06:08 PM
  4. Replies: 2
    Last Post: 01-04-2015, 06:05 PM
  5. Face down to silence notifications?
    By BlackDragon22 in forum Motorola Droid Turbo
    Last Post: 01-04-2015, 05:04 PM
