DevilJack
If they get white I'm getting it. If nothing changes may just go with the 4.
Sent from my iPhone In league with Satan
The Note Edge is limited release and will only be available for a short time. VZW will not offer any changes whatsoever. Don't wait for it.If they get white I'm getting it. If nothing changes may just go with the 4.
I had the same problem, I had to agree to the notice that the app was waiting on then unchecked it and rechecked it. Now it works.Anyone havin trouble with the CNN panel not working efficiently? It works for awhile then says loading
It wasn't Lollipop. It still shows build 4.4.4
Just got the notification.. Hopefully its a precursor to lollipop ^_^
This update is definitely in preparation for lollipop. Just some nerd talk... When this device first came out, if you go under developers options if gave you option to switch from dalvik to art runtime but it didn't work. This update allows you to switch to art runtime permanently (don't do it though, things didn't work properly for me.). As you know, lollipop defaults at art runtime so it's definitely coming.
Sent from my Note Edge
Verizon is usually last with updates but I have never had issues with the phone after.
